From Nissan Silvia
Hey all
Micheal and the boys at Turbotune here in Adelaide have recently finished playing with an RB20....
this is how it turned out!!!!
SPECS:
Std capacity R32 RB20det
Std original pistons
Std rods and crankshaft
New rings and bearings
Metal Head gasket
Std RB20det camshafts
Ebay adjustable cam pulleys
Std head
Shimmed Std Valve Springs for extra seat pressure
GTR inlet plenum dodgily welded onto rb20det inlet runners (none of the runners line up, it's awesome)
850cc injectors
Fuel pressure regulator
Ebay 100mm throttle body
Splitfire coilpacks
Ebay Stainless highmount manifold
Ebay External wastegate
Monza 600x300x76 fmic
T04Z turbo
Remapped Std ECU
370rwkw
Limited by cams, traction and stupid tall diff ratio. Hits dyno maxspeed, power still climbing
crazy stuff... the dyno only has a 2 bar map sensor so they think the boost was going up to around 35psi!!
EDIT: Tuned by the one and only Jeff from The Speed Lab!!!!
EDIT::: as people dont understand!!!
I think you guys have taking this the wrong way lol
this car is not a customers car its not a car they drive on the road/track or anything it was made just for and only for the dyno!!!!
The motor was built after hours for a laugh just to see what they could make out of a standard RB20..
It didnt matter if it was laggy or cheap or if it blew up.... they didnt care...
It was made out of spare parts lol
Cheap and easy.... just to see what they could do with a standard motor and a remapped ECU!!!
It is turbotunes car that they made for the hell of it!!! And no... it wont last long..... its running 35psi lol....
I thought it was a bloody good job lol.... Its handled around 40 to 50 dyno runs over 320rwkw’s so far!!!
Dont mess with the strength of an RB20
Wow 500hp RB20! I didn't think the rods would live over 28psi.
  • 1 month later...
I have a worthy RB20 to add to the list, but i would be cheating some, my donor chassis is a 2520lbs 240sx (2700 w/me in it) hehehehe, managed a 11.07 at 128.8mph, 1.521 '60 at low boost (22psi), and from experience, I'm well over 300kw at the rear wheels
the 11.07 run, 1.521 '60: http://videos.streetfire.net/video/19672bf...99e00b51eab.htm
an earlier run 11.48 at 114mph, 1.524 '60 : http://videos.streetfire.net/video/a8b026e...98e0175d428.htm
running slicks of course, 26 X 8.5 X R15
I'll be crancking the boost some this summer with a few more mods, looking to be in the deep 10's, how low i'm curious
Sylvain
well the season started over here in Canada, went for some tunning at the track to get things going and I pulled a 10.94 on the quarter with a 1.56 60', after some little tunning, it pulled a 1.46 60', clocked an eigth mile of 6.9 at 102.8mph but 2-300 feet before the quarter trap my intercooler piping blew off bringing the strong haul to a 11.15 at 102.0mph, next visit should be a solid 10 run.
the launch: http://videos.streetfire.net/video/240sx-R...0-at_162048.htm
I see some serious power from 20's in this topic lately!!!!, good stuff!!!! can't wait to get my shit together and get a dyno graph up in here. I'm surely not close to the last one, but eh, got to proove at least the 260rwkw, hehehe.
laters guys n gals
Side
Edited by FastRB20
  • 1 month later...
Finally had my car tuned last night....
Mods applicable are:
Trust/GReddy TD0620G-L2 8cm Pro Kit
front facing plenum
550cc sard injectors
R32 GTR PFC (D-Jetro)
Bosch 023 in tank fuel pump
FMIC
Exhaust
Blitz single plate button clutch / flywheel
Trust/Greddy Iridium plugs
Splitfire Coilpacks
1.25bar of boost 7,000 rpm redline, rev limiter at 7,200
277.1rwkw on a Dynapack Dynometer
Makes me happy in pants :)
Edit: Found the sheet already here :thumbsup:
http://www.skylinesaustralia.com/forums/in...t&id=172954
Edited by Wheezy
  • 1 month later...
I know this isnt the For Sale section, but am putting it here as i would really, really, really, really love for someone with a car that is basically well setup with a turbo setup and good tune to buy the HKS 264/8.5mm cams i am now off loading.
Was going to try and get another good baseline before / after but i have lost interest in chasing setup of my car at present. But if anyone else has the motivation to play with their RB20 a bit more...mine is parked at present :)
Was going to try and get another good baseline before / after but i have lost interest in chasing setup of my car at present. But if anyone else has the motivation to play with their RB20 a bit more...mine is parked at present :ninja:
my ears are burning :) perhaps a price?
Price is negotiable based on what they are going in :/ Engine is still running fine, car isnt :dry: Has a dent that needs repairing from an acco ages ago...needs some life put back in the suspension and brakes....just getting a tidy up whilst i am busy with work.
well i broke the 260rwkw mark but im not happy with it really comes on full boost at 5500rpm
im runnin a gt30 at the moment thinkin bout down sizing
what do you guys reckon the quickest setup would be? a big turbo or a small to medium size on the rb20??
  • 4 weeks later...
i've got the graph here - injectors are 100% on the pfc :/ so tweaked the FPR - i'll be upgrading injectors soon so will be good to see where its at.
It was wheel spinning on the dyno still aswell, while it was strapped and water in the boot.
still running the GT 3076r, 56 trim, with the .63 IW housing on standard manifold, standard inlet side - only mods to the head are tomei poncams and tomei cam gears (gears are both at 0 still). Boost is up to 25psi - realistically i think i'm reaching the peak of the turbo. but it's good to see some numbers. I'd like to see the max i can get with change of injectors.
Did u drive it ? How does it pull ? Where is your dyno graph?
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
