Be interesting to see the power the thing makes at 4,000rpm and again 4,500rpm. It could be finally enough for me to remove the TD06?!?! At 25psi , 274rwkws and 0.63IW housing how is the boost curve. I imagine the back pressure muct be pretty high in the housing, what ignition is in the engine up top?
  • 4 weeks later...
So after nearly 3 years off the road i finally have the new motor in the car :P
New set up is:
Rb20 with 70,000ks
TD-06 20g 10cm (want to change to 8cm but will see how we go for now) this is the full kit with manifold, 47mm gate (1bar spring) etc
HKS 264 cams
Tomei 555's
GKTech cam gears
HYBRID GT cooler
Just Jap oil cooler
Bosch 023
PFC
Tuning will be done in the next few weeks once i get a Z32 sorted and new SABER gauges fitted to keep an eye on everything and get my hands on the knock sensor im missing :( Looking to improve on the 205rwks @ 14psi with the addition of cams/injectors/Z32.
Will post up results when done :blink:
Cheers Ben
  • 3 weeks later...
an update - only change was from gtr injectors to 550's - got a power run to see how it went (*note not a tune*) and it came back with this...
recorded on a brand new dyno dynamics, twin retarder dyno @ MORPOWA in SA.
**obviosuly AFR's aren't the tidiest...but as i said just to check with the injector change - i reackon it would've had more in it if time was spent tweaking the tune**
Edited by huddy
That was on the 2.4
Unfortunately... not going to be able to find out what it would've made with the tune... as the engine is out now (SOLD)... so one of my last posts for this thread...
will be posting in the RB30 thread if all goes to plan...(not for a while though lol)
Hey guys,
I've been following this thread for quite a while now, and I finally have the chance at cracking 260rwkw. My setup is an oil line and a cold pipe away from running. Anyway, I hope you like it.
Holset HX35 (8 blade, wastegate welded)
Turbonetics Deltagate
6 boost Fwd mount twin scroll manifold
440cc's
Constructive criticism or complements are appreciated!
Thanks!
-Max
I've got a td06 20g 8cm and cant get rid of a boost spike, has a 6boost manifold, had a 38mm tial gate now has 44mm tial gate, exhaust is 3inch straight thru, has anyone else experienced this problem before, my tuner told me at the first tune the manifolds are TO GOOD so thats the reason i upgraded the gate. it boosts to 1 bar then spikes to about 1.5, was going to 2 bar before gate change. would going bigger again fix this problem?
How big is the spring your running in the 44mm gate? if is the standard spring get a bigger one and see if that will help. And are you sure it's a real Tial? the knock offs are getting hard to tell everyday.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
