Top RB20 Club... do you have over 260rwkw?
This is all too easy, and way too much fun these days.
Just got back from Winton Raceway, only did two sessions so about 10 laps...but at 18psi and 8,000rpm rev limit (shifting around 7,000-7,5000rpm) the engine ran well:)
Do have a problme though, my piping has a boost leak somehwere that meant i wasnt able to continue after the second session:(
  • 4 weeks later...
I had to dig up this old post........gotta love it.
This is what was pushed out of my rb20det.....with 2530 and rest to support 200rwkw. It isnt quite what roy has, i wish. ;)
Could someone also tell me how to convert kph to rpm on the graph....i saw a post once explaining the formula.....but i cant find it. :)
This is what was pushed out of my rb20det.....with 2530 and rest to support 200rwkw. It isnt quite what roy has, i wish. :D
Could someone also tell me how to convert kph to rpm on the graph....i saw a post once explaining the formula.....but i cant find it.  ;)
Hey, that looks nice and punchy, :)
What bosot is it running? Im off to Eastern Creek today so should have a tale to tll tonight:)
Cool, email me at [email protected] and ill send over a spreadsheet, either that or tell me the tyre you are running and brand, as you need th etyre circumference to work it out...its pretty easy to do:)
sure no worries
turbo = 2530
booost = spikes to 18 then tapers off to 16psi
ecu = power fc
gtr pump
gtr injectors
cam gears
front mount cooler
blitz ebc
i dont like running that much boost on the road.
i wish i could have full boost by 3500rpm....make it even better.....maybe i'm asking too much :rofl:
u mind if i ask who tuned your car... ill be putting in pfc pretty soon looking for a tuner for my 32
going by the dyno sheet, Croydon Racing Developments..... :P
Good power, seems a bit like mine up top, drops boost and power just after 6000, although mine drops of a bit more than that
highest i've seen it was 69.8% last night.
Would anyone be able to tell me their settings for the injector data option on the fc commander??? Curious to see if any changes have been made to the lag timing of the injectors
Looking at that result i say the 2530 has to be one of the best bolt on options with the RB20, perhaps the 2535 will make a bit more power...but who knows for sure.
One thing that seems evident is that a good manifold and a good external wastegate seems to help the things make power. My turbo seems line ball with the 2530 down low but makes a bit more up top...but you have to question the value, the wastegate and manifold alone are worth what the 2530 goes for...then you have to buy the turbo and plenty more in the way of lines and piping:( So is the extra 15-20rwkws worth the expense???? If i want to run 20psi and make the power then its handy but 18psi day to day is enough for the dry
The 2530 seems to be the go, but interesting that boost even falls over at high revs on the RB20:confused:
What brand / size exhaust and cat are you running?
Oh on another note on my old girl, the only drama after 6 x 20min sessions in the wet at Eastern Creek was a tired alternator about 15mins into the last session, where voltage dropped to the point where i got a misfire and steering went heavy. Another alternator in and she is good to go:)
So that just about 120min of spinning around on a wet track with either 12 or 15psi, i cant remember what the low boost setting is...lol i need to get my boost gauge working....and not a drama:)
The catch can is still empty with only a bit of mist on the hose walls :D
Its a 3inch full peice front/dump, 3 inch catco cheapo....3 inch trust renonator.....then opens to a 3.5 inch till the rear muffler and 5 inch tip (looks dicky)
Looking at the latest dyno sheet for mine, I have approx 600rpm more lag than the 2530 (running 1bar) but power doesnt drop of untill around 7000rpm. Thats with std manifold modded to accept the external gate. Waiting on a stiffer gate spring so we can wind up the boost and give it a proper tune (hopefully the stiffer spring and tuning will reduce the lag slightly).
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stop on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, you need to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
