Ive got bilsteins in atm, but need a wheel alignmet, bushes/pinapples for the rear then get some better rubber...(looking at Toyo Proxes R888:drooling: ) Im curious to know a time as well, but shes all wheelspin for 2 or 3 gears in the dry atm...;)
Even when launching the way you did when it was making 200rwkw? :D
Here it is.. :D
Does 125km/h sound about right for 5000rpm on your dyno sheet Roy?
Its actually 4,550rpm. Seriously, if you lived in Melbourne id consider doing the swap...it takes me about 2.5 hours to completely remove the turbo setup:)
Id love to drive such a grunty car at the track, would really make you feed in the power and learn throttle control. Get the bigger turbo on there and rubber/alignment and the thing will be awesome with hopefully good traction:)
I got a rb20 180...
http://www.nissansilvia.com/forums/index.p...0entry1413806
Not sure of the power... Was going to get a new tune and power run done tomorrow but had some dramas today and think the head gasket has blown some how. Checking it right out tomorrow to see but once thats fixed ill get the tune and power run and post up my numbers :D
Seriously check if it has blown a head gasket. Every one that looked at mine said it had an gave me big quotes for a repair.
I had bubbles spewing out the overflow and it overheated every two seconds.
It turned out to be a bad clutch fan, 2 x 12" Davis thermo's went on, summer came and the same happened again. I dropped a good clutch fan back on it and its been fine since.
The RB20's are pretty tough and hardly ever pop headgaskets.
osiris23 (lol another RB20 powered Troy:)) love the avatar.
I have heard of a few head gaskets failign because of corrosion, but if the thing always runs coolant instead of water i would think its rare. They dont seem to blow gaskets even when they have over heated
well i got twin thermos on my car already..
Alright what happened was i was driving alone today just normally and started to smell something, slowed down for a sec to listen for anything then noticed white smoke comeing out of my right side bonnet vent.... Pulled over right away and poped the bonnet and had white smoke comeing out of my oil catch can breather. Didnt know what the hell was going on so i called a few of my mates and they came and looked at it... Worked out at first earlier that day i was washing my engine bay and must have got heaps of water in my catch can and the water was boiling or something?? Empted the catch can and yer it was full of water but put it all back on and it was doing the same thing but not as bad..
Took it to a mechanic mate and he rekons it was a blown head gasket but getting a compression test done tomorrow to fine out what the problem is..
What do yas think???
one other thing i might add is the car still drives fine apart from the smoke, still boosts etc even though im not if i can help it at the moment....
The boost controller fell apart a few weeks ago so i had been running the boost through the external wastgate and was only pulling 10psi constantly but hooked up a new bleed valve today so the psi was back upto the high level and yer it started playing up... so i duno if i cooked something or it is the head gasket or what..
One more thing the radiator overflow tank was full to the top, usually only half full, the radiator it self was full as well so i was a bit worried about that fluid not being in the motor? :S
temp guage was normal as well i might just add... oil pressure and VAC on the boost guage where normal to...
Did you put the R32 Temp sensor in or did you put the Silvia temp sensor in? If it's the R32 (looks like your running the Slivia cluster) the temps will read diffrent and the car will look like it's not even heating up.
Well after finally sorting out the new ignition set up it made 235rwkw at 16psi but Im not happy with the result.
Previously it made 225rwkw with 12psi. Overlaying the two graphs the 12psi run is ahead on power all the way untill over 5,000rpm and it comes on boost noticably earlier as well. The cause has been a melted cat from all the rich running sorting out the igntion dramas.
And to make matters worse I had a nasty vibration from the timing cover two days after getting it back which has revealed itself to be a shot idler bearing so its off the road again.
I have an R31 Club drag day on the 20th of August so I will just pull the cat back system off and see how much wheelspin I can bog myself in on the line and report back.
**edit. Here is the graph. Red line is 7psi. Blue line is 16psi.
Well did the compression test today on the car... 1st cylinder was 70 dry 90 wet, and 2 3 4 5 6 was 140 so come to the conclusion i have a cracked piston ring..
Thinking of just selling the car as it cheaper and let the new owner fix it up as i just dont have the time or money...
im currently sorting issues with my rb20, have to fab up a real intake as the old girl doesnt like sucking in air right off of the manifold.
rb20 + gt30r seems to be the mint way to go, but i have yet to get a proper dyno as im still chasing problems related to power.......
i will post pics of my latest setup as it should be fun when all is said and done.....
went and picked up my fresh RB20det this arvo... Sounds like it is perfect... from a 4WD cefi auto and dead stock so sounds like it was from a family car..
Be chucking it in in the next few days or so hopefully..
How much do you guys rekon i could get for my other RB20det? It has 50thou over sized pistons etc... how much could i get selling it just the head and bottom end etc... complete just without the manifolds etc?? Would be perfect for a further build up and more power :P
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
