Yeh but what about that bloody front bar you have that should have been mine...thats good for a few kws....i dont think i will ever swallow that deal you got with that bar...im still looking :D
you still going on about that!
looking forward to giving a few 33 a nice run with their fmic and pfc's!!
pfffttt
B)
http://www.skylinesaustralia.com/forums/in...showtopic=81906
I can get 5+ AP engineering power fc to suit R32 GTST for only $1150 delivered each.
If you require the hand controller then the total price is $1470 delivered.
Pretty damn good price. You would also get the AP Engineering keyring with that. :)
too much $$$ for me
It does depend on who tunes the stock ecu, generally with the pfc you will pick up mid and possibly a little top end with say a pfc as the tuner is able to push it closer to the edge with the use of the pfc's knock feedback.
I.e Chris32.
Yeah, Cubes is right. I'd go a PFC, my experience with the chipped ECU I had was ok, but I picked up 45rwkw through the midrange. It went from feeling like a laggy dog with a GT30 sized turbo on it to a very responsive package. 8rwkw overall more right up top
More to do with the injectors I think, as they where at 100%
My GTR injectors are at 70% making 205rwkw now
Cool, heaps left in yours then Roy
When are you going to wind in 1.5bar?
Looking at doing a few things to mine again soon, starting to get the bug again and want to go a bit further
I reckon some Poncams + exhaust manifold for me next
I want to crack 220rwkw with the tiny turbo I have :D
How much difference is there between getting an S-AFC tune.. and getting the ECU remapped? Is the main difference that you get very "peaky" power, compared to a broader spread in an ECU remap? Does anybody have any dyno SAFC vs (standard) tuned ecu ? If its a big difference, I might be pursuaded to go the remap.. but for me there are many reasons to just use an SAFC for now.
It something like PFC > remap > SAFC I assume.
I'm unsure what a remap is worth up in your neck of the woods, down in SA I was quoted $600 for a remap.
I picked up my PFC for $1100 and tunes are costing me $100 (more boost bigger turbo etc) and $200 when injectors are swapped as it requires a complete light load afr change.
I asked what it would be worth to remap the std ecu again to accept the larger injectors. I was told, again another $600. Thats 2 remaps and it would have set me back $1200.
I figured within 2 tunes I would have basically broke even with the PFC.
The PFC $1100 + $100 + $200 = $1400.
To be honest I don't see why they would want to charge $600 to simply swap injectors and dial a little more boost in. The hard work has already been done with regards to the ecu mods.
We will see. :P
Waiting to get the body and rego sorted on my car, plus a general tidy up. Then its the diff then having another play with a few things engine/power wise.
Right now its got enough power that my chasis is starting to show signs that it isnt easily coping like it use to...so really should spend the money on the susp first but we will see. But the thing will be fine with another 20-30rwkws, though i think it will be quicker with better suspension rather then more power so thats where i will most liekly spend the dollars
At the moment i need to make sure the car gets me thru the next 3-4 must do track days then i might start leaning on it again
An SAFC is simply an AFM voltage bender, it changes the voltage that the ECU sees from the AFM. When you bend the AFM voltages a lot, the ignition timing is also affected. So you may end up with too far advanced ignition in order to get the A/F ratios right. As I have said many times before, piggy back (benders) are a compromise. You might have to run it a bit rich so the ignition timing is not too far advanced.
On some cars this compromise is huge in max power, average power and response, on others it's not so bad. Every engine is different, but one things is for sure, the further you upgrade from standard, the bigger the compromise.
:P cheers :P
Pretty damn good price. You would also get the AP Engineering keyring with that. :P
Now can be done a little cheaper as well :P
I looking for around 260rwk's with mine hopefully once i get the Power FC in and get it tuned.
Cheers B
Silver gts-t I chipped my stock ecu myself. Its quite easy to do if you know anything about electronics. I just socketed the ecu, then programmed a new eprom chip on my eprom programmer. Its not the best tune. I just changed the settings for injectors (550cc), the afm (z32). Im running only 10psi, so i haven't messed around with the fuel maps to much. I've added abit more ignition timing and it seems to go fine. When I eventually put the new turbo in I will have to redo the fuel map. Its quite expensive to get your ecu chipped by a dynotuner. So if you have access to an eprom burner i suggest you get your car dynoed, have the settings put on a disk and then burned onto a chip by yourself or someone else, you can save mega $$$ this way.
toshi on the forums was only charging around $250 this removes speed limit and you can set your own rev limit also, which cant be done with safc.
you provide him with a list of mods, he sends you 2 ecu's u pop the car on the dyno, u c which ecu is best suited and send your ecu and the one that didnt suit ur car back to him.
seems good enough
just looking into how you do it at the moment..
just type in "rb20det roms" or "rb20det programming" into google and away you go .. changing the rev limit, removing the boost cut, and the speed limiter is simply a matter of typing in the boxes. As for the tuning, that is the part where you need the knowledge.
you are looking at about $60 for an EPROM programmer, and about $10 for the blank EPROMS..
Here are a few experiments by people.. http://www.tangentrix.com/forums/viewforum.php?f=2
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
