its internally gated...and i dont have injectors yet, but thats next on my list. the guys who r doing for me (race solutions and hitman in penrith) asked me the same question bout injectors, and after i told them i havnt done them yet they said theyll see how far they can push the stockies....im hoping to get injectors done after christmas :(
Without injectors done forget about joing the "260kw" club. And if its a TO4 with internal gate have you got a pic of it?
When you said turbo rebuilt to TO4 specs did you mean your stock turbo supposedly built to TO4 specs or another turbo that you have purchased?
oh and im not expecting to get above the 260 mark without getting other stuff done, meaning mainly injectors (which is my next project) and a fuel regulator...i was simply stating what i have gotten done thus far, so please dont treat me like an idiot...as im not one, with what i have done so far, im realistically hoping for 220-230 atw kw, just thought id make that clear...thanks
Edited by R32_GTS-4
so is 220-230 theoretically possible with standard injectors?
no, stockers rated at 270cc's are crap for 240 HP at the wheels, they will be maxed out at that power.
100% duty cycle is not your friend, you should never run over 80% for safteys sake.
hell, im taking out my 550's and going to 720's just to have a low duty cycle, and thats with about 450bhp.......
Mine were hitting 92% duty for 176rwkw. Keep reving it past peak power and it required 100% duty to hold a 12:1 AFR.
They were slightly dirty as cold starts would see it stumble slightly.
Depends how happy the dyno is if you make 220kw with std injectors.
All though at the dyno day there was an R32 running stock ecu, stock airboox, exhaust, fmic, HKS GT2530 @ 1bar. That made 178rwkw.
Unsure if injectors were at their maximum, it now requires an FCD to make more power.
Edited by Cubes
maybe past 240hp at the wheels. Thats where I'm at with the stock Rb20 injectors @ 14psi with the stock turbo.
That dyno is either very happy, the injectors aren't really standard or the fuel pressure is way above standard. There are no miracles in engines, including fuel injectors.
:angry: cheers :P
:) cheers :)
Well not a happy dyno but I do have a 255lph fuel pump blowing past the stock regulator :)
I recently had my GTR injectors flowed.
Base fuel pressure set was 40psi.
@ 100% duty they flowed 474-480cc
@ 80% duty they flowed 384-390cc.
So theoretically, say the GTST injectors are 270cc's.
270cc's * 0.8 = 216cc (80% duty).
Isn't the old rule of injectors 1 cc per hp. 216hp.
Or is that 1cc per hp based on 100% duty flow i.e 270cc @ 100% duty makes 270hp at 80%duty.
Kind of messy but hope it makes sense. :)
Stock RB20DET running 14psi with a tuned ecu (PFC) on the dyno's I run on generally make spot on 170rwkw.
Edited by Cubes
Hi R32_gts-4
550cc will get you the rwkw your after Matt tuned mine with 550 and there still on standard presure and im running 238rwkw on his dyno with other mods to though but if your running a to4 as i was i think u might be battling i had mine rebuilt twice and it still dont flow enough runs outa puff at 6800rpm and its rated at 500hp
Cheers Peter
Edited by legend01
hey thanks for the info guys...i have another question, does anyone know the part number for bosch 550 injectors, i called their inquiry line and they have no idea, great help they were haha
also does anything need to be modifyed to fit bigger flowing injectors? i heard somewhere that u need a higher impedance, i think? is this right, or am i getting told crap??
thanks
thanks
hey dude, I have a set of Nismo 555cc injectors in my GTS4, they are straight fit just plug in and go. Don't worry about some obscure help line, just go to a site sponsor or nengun (where i got mine) and get them cheap and the best quality around.
I've had my 555s for 3 years now and once tuned on a RB20 like you then idle and economy is perfect. Can't go wrong! :)
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
