thanks for the info mate...how much dosh would they set me back?
where do i get them from?
as i said in the above post, nengun or any site sponsor or even site sponsors at ns.com as they have some really good deals sometimes.
Mine cost me $1050 3 years ago delivered and that was when the exchange rate sucked. now a set of 6 should cost no more than $900 delivered.
no, because the stock injectors are high impedence. so its a straight fit.
if i get high impedance injectors...do i need to use a resistor pack? (i think thats what its called?)
thanks interloper...i went to that nengun performance webpage and found some sard 550cc injectors to my door for $690, can anyone tell me though...what twin hole spray injectors are?
thanks
Edited by R32_GTS-4
i also have another question, regaurding power fc, does it remove the speed limiter, boost limiter and rev limiter? would i be better off getting a haltek e11 or a power fc?
Edited by R32_GTS-4
go the PFC, it does all those functions and more!
I would have bought one but i decided to get the stock computer remapped instead :(
I've found the trick with the pfc is to ensure you set idle with the aac valve solanoid disconnected and set the idle as close to to the pfc set idle rpm. The trick is to get it spot on.
Then... init the pfc (also a must as it doesn't seem to relearn as well afterwards) and let it do the 30minute idle thing with a/c off then a/c on.
The only time I have a slight elevated idle is occasionally with the a/c on, even then it settles to the usual a/c idle rpm within a few secs.
But definitely no hunting.. when I had the motor out I cleaned every single little thing.. throttle body, plenum, aac + the cold start idle control i think thats the ICV or something can't remember exactly.
I must admit I can't remember any idle hunting while the motor was being run in on the stock ecu. Maybe it wasn't the pfc.. maybe the cleaning?!?
sky30 with his 300rwkw monster has gone through quite a few rb20det box's. BUT it is a 3ltr and its torque that kills gearbox's not power.
Third gear is appears to be the one to go..
No hard changes, mid way accelerating through third it goes BANG!
Oops. Sorry to hear. Out of interest what clutch are you running, kms on the box and what fluid were you running?
Also how hard are you on the box, do you clutch the thing mid corner, burnouts, flat changes etc etc???
9 puck brass button clutch... box is unknown kms cause of man conversion and i was running redline oil
im very hard on the box, i clutch mid corners, i drop 2nd a lot in the dry from standstill... decently fast changes not quiet flat changes but close
box held up for a full year of abuse with around 300rwhp but finally gave up on me... im actually quiet impressed that it lasted this long. just popped now cause boost has been raised and intake pipe which was collapsing has been fixed. like the day before it happened so im hoping this isnt too regualr occurance
if you speak to R32-Gts (simon) on these forums, he has broken so many rb20 boxes its a joke
thinking of getting a spare box cryogenically treated and shot peened, i cant be bothered forking out on a RB25 item
yeh dude i know the feeling well!!!! i went through 4 of them! 2 with the 20 and 2 with the 30 then i finally got sick of forking out the cash 4 the shit boxes and bought a 25det one and i gotta sa man i should have done it a long time ago coz it is sooooooooooooo worth it!!!!!
This is my car
and as i'm sure you can guess it's got an rb20det in it
just got it back from the tunners the other day and it's got 241.3 rwkw with no real power loss right up to 7500rpm.
It made 253.8 rwkw but was runnin a little lean 12.5:1 so we tuned it back to a safe point .
i know it's not really 260rwkw but hey it's got 322rwhp so i thought i'd post it up.
By the way roy can you give me the formula to convert speed to rpm
Cheers
anthony
Edited by black sky
    • Well, if it wasn't a GTR I'd say that killing an RB is a perfect opportunity to put in a proper engine. In your case, proximity to Brabus and AMG V12s would be a no brainer for any RWD Skyline engine death event. In my case, because my car is my daily, anything that I do wrong that means I have to do it again is both an absolute pain in the arse (simply having to do it again), and also a doubling of the pain associated with having the car off the road to work on it. I would class a botched head gasket install as not being "engine death causing". More a case of "f**k it's still leaking!"
    • Yeah, this is more stuff like transmission/clutch R&R. Intake manifold R&R. It's not super complicated, but each step matters and you need to be careful and patient. I have heard stories for example of people not figuring out the super coppermix twin plate orientation and getting it wrong on assembly. Removing a cylinder head and putting it back in once it's machined isn't that hard, following torque sequence to install some cams isn't that hard either, but somehow I've seen a lot go wrong between here and there. Scraping off all gasket material isn't that hard either, but I've seen shops ruin heads by using a roloc disk that was too aggressive.
    • There is some shops in Germany that have quite a bit of experience with JDM performance 4-wheelers. I think if it actually comes down to it I'd let one of them do the head gasket. Killing an RB26 is too expensive a risk just to save some money by doing it yourself.
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
