gonna have to get my car dynoed when it comes (eventually), hopefully after some bigger injectors go in and raise the boost a tad, first i have to get it engineered and rego'd tho :P
hrmmm watch this space, twin turbo RB20 R31 has arrived today, drove it down to autosport engineering to get started on it.
The previous owner said it made around 160rwkw and the mods are as follows:
FMIC, twin turbo setup using RB26 turbos and manifolds, 3" exhaust with 3" hi flow cat, 700hp fuel pump (have to ask him what brand or dig up the receipt), heavy duty clutch (once again have to dig up the receipt or ask him), microtech LT8 ecu, twin pod filters.
I must admitt, when driving it, it did feel like it went hard, even though i wasn't pushing it too hard, but the figures he told me were, well, somewhat lower than what i'd expect with this sort of setup. ATM it's running 9psi boost and injectors are at max or very close to max duty cycle (standard RB20 injectors, had some 800cc/min ones on but the bloke said they were meant for rotors to he took em off and went back to standard as they were stuffing up or something).
Can anyone tell me if these figures look about right? I might get it re-dynoed/do another power run once it is engineered to see for myself.
anyway, would these figures be fairly typical of a setup like this? (not common, but if you go off factory turbo specs it might give you some idea/grounds for comparison)
Sum it up?
intake, decent sized turbo, efficient cooler, good dump, 3 inch minimum exhaust, injectors, fuel pump, ecu with a good tune, big hit of boost, wait untill about 4,000rpm for the turbo to wake up, HANG ON while it skates across the road = 260rwkw.
Oh, last but not least the most important mod of all, MONEY!!!!!!!
Sum it up?
i'll add,
Z32 airflow meter, unless your obviously using a MAP sensor in which case you can remove the AFM restriction :mellow:
with RB20 the best options for ecu are: remapped stock ecu or Apexi PowerFC.
my 2c.
Well finally drove my car today after 3 months off the road putting all the original kit on (had to do pretty much everything again as the crazy japs bodged everything). but anyway feels fast, very laggy though, as in doesnt pull boost till about 4k and full boost by nearly 5k (even with the rb24).. hopefully get it on the dyno on monday to check that everything is sweet a/f and knock-wise and i'll post up my results.
gearbox doesnt sound promising, gave it two quick squirts in 3rd to about 6k and its already sounding like the mainshaft bearing has collapsed.
update early this coming week and hopefully gearbox lasts the dyno run and i can make it into the club :blink:
dodgy phone pic:
Edited by kwazza11
update early this coming week and hopefully gearbox lasts the dyno run and i can make it into the club :P
dodgy phone pic:
holy fiznuck!
whats the ar on that turbo? from the pic the housing looks absolutely ginormous!
just curious but how do you know its a rb24?
also is that the gtr intake manifold mated to the rb20?
ar is unknown probably a .82, wheels are huge though, 72mm front and rear! its a kkk k27 and apart from that i've got no info on it.
bought the car in japan with the gtr crank and rods with tomei 82mm pistons already in it. havent actually pulled the sump off and measured the thing but from the feel of the motor with standard everything its definately more torquey than my last rb20.
and yea manifold is 2/3rds rb26 and 1/3 rb20. basically rb26 injector bosses welded to the plenum then that welded to the end of a rb20 manifold. not the most advanced piece of kit but should do the job now that i've ported it to get rid of the weld protrusion they left in there.. :)
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
