LOL...a few ppl were looking very hard at my engine on the weekend as a few of the guys know the gear i have laying around and the car had been at the mechanics for a few weeks. So there was some suspicion that it was still my RB20. I think the fact that i left the bonnet restraint on and i didnt lift the bonnet all day also had a few ppl curious.
Why would you spend all that money putting in an RB25 to make 200rwkws max. When for less money you can bolt on a nice turbo and keep the big brother honest :)
And it has been reliable. I would like to see how a full 2835 setup would go an RB20. GT30R seem to work well as well, but you are perhaps throwing away a bit too much 3,500-4,500 power to make the big top end. Still those that have done it are still quicker then me over the qtr so...GT30R obviously works as well :)
Yeh...just a few more hours to get the most out of it. Worth every cent.
Witness...RB20GOODNESS!!!!!!!!!!!!!!!!!!!
Clicky_Right Save As . approx 40meg of RB20 running around Phillip Island
So if mine can hang together after plenty of track work...the average street driven RB20 will be quite at home punching out good numbers
If i go out on the track with less then a qtr of a tank it gets fuel surge. As long as its above its ok. Couldnt be stuffed with a surge tank. its just more lines in the boot that can be knocked/damaged by stuff thrown back there.
The car is still my daily driver so dont want to lose the practicality of the boost. Some of the jap GTR pumps have a in tank baffle that i may look into if i ever need more flow then the 040 can provide (Highly doubt i will need bigger, i think it flows something like 235L/min?)
Great vid Troy!
the thing with the average RB20 its that they need a good tune (like yours) there's been plenty fail at only 200rwkw due to crap tune/detonation....
IMO - its all in the tune :)
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
