Personally im thinking i dont really want to throw away the nice long runners of the std RB20 inlet manifold. Has anyone actually put one of thee short runner manifolds on and gained torque?
I have a spare inlet manifold that i am tweaking to see if i can get a bit more out of the RB20...it will be a purely back to back test so will be interesting to see my results?
The gibson HR31 used the standard over the top plenum and still made some serious power (300kw+). I'd personally leave it as it is unless you really have run out of room.
Edited by Rolls
i have a std inlet plenum,throttle body, cams, gears, springs, the entire motor was unopend and were making 300rwkw! 405rwhp to be exact, lasted over 6 months on that power befor i changed the setup and added cams and a new turbo, it recently gave way haha
and the lesson there adam
if it aint broke... haha
what's the plans for the future?
too right there, we lean on this thing so hard its crazy its lasted a solid year of 20psi+ of boost haha
i honestly cant say yet because i really dont know! we're looking into building the 20 but its going to come down too how much we can squeese out of the 20 head in terms of flow.. probobly have an attack plan in a couple weeks
DAMN, wish I had just changed my Inlet manifold after a dyno tune then compared it again.
That would have answered all these front face inlet manifold questions! :/
BUT I didn't! :rofl:
Changed a whole heap of things at the same time inc the highflow turbo...
LOL so its still running, with blowing out hte dip stick and blow by or is it proper farked ? :)
hahah yeah it still runs,cable tied the dip stick in :rofl: still gets a bit off boost aswell haha :/ the 20 just wont give up in a big way!
Edited by AD4M
hahah yeah it still runs,cable tied the dip stick in :( still gets a bit off boost aswell haha :D the 20 just wont give up in a big way!
OK, so I dont quite have 260kw yet, but I thought I'd share about my motor while you're on that subject.
I'd been running around on about 270 hp with my RB20 which was probably a bit too lean. Ran strong for a few months with 16 psi, took it to the track and blew up on the first run. 1st and second gear felt like a bat out of hell! I felt a surge of power after hooking 3rd gear and babied it across the line for a 14.0 @105mph. Popped the hood, found had blown out the PCV considerably, and I had audible piston slap.
I drove the car for another 2-3 months before I had another motor lined up. When it was time to kill the car, I raced a buddy's 88 civic hatch with a b18. I got about 2-3 cars ahead (100mph or so) and looked back only to see a giant cloud of smoke left behind. Parked it a mile later and tore out the motor.
I think the moral of the story is the RB20 is stout as hell, and no matter how low the compression, it has too much pride to let itself loose to a honda.
I have a new motor in my car now, and a few mods that I'm just hoping to get over the 300whp mark with
Garrett t3, .60ar compressor .48 ar turbine 60 trim
tomei poncams
mild port/polish
supra 440cc's/nismo FPR
reflashed ECU
SAFC
I'll post a dyno graph asap, so I can actually contribute something of worth to this thread!
-Max
just so everyone knows, adam may claim all this power but he does drive little a nanna :D
jks, he absolutley belts the shit outta that car, 3th gear peeling lines in traffic. got more mental problems than me
in all seriousness, i cant wait to get back to the dark side of rb20 love!!!
Edited by Cerbera
What is the most anyone has gotten out of stock cams with adjustable cam gears? I'm looking for about 300rwhp or about 482rwkph. I have lots of other mods, so I do know they will effect my capability, but they will allow for that power range. Right now, the cams are the only thing holding me back for being able to breathe. Thanks mate.
300rwhp or what?
I am making about 340rwhp with std cams, valve springs, head, plenum, throttle body etc. I run a Greddy exhaust manifold and HKS cam gears. So doesnt seem to hurt power too much...i havce tried one set of cams with less then spectacualr results. So just be careful when chsoing cams to make sure they suit the turbo/engine configuration
wow... sorry Roy about the rwkph. I was trying to say miles per hour and translated that to kilometers per hour in some other computation and somehow got it mixed up with my horsepower computations and such. Been trying to figure out several things here, but you answered my question entirely. Shit, I dont know how many times you have helped me in both answering my questions and with the many posts you have done in the past. I will be posting my power here hopefully in the next month or two. Finally I'll be about satisfied with it.
Edited by Draconis
to back that up... i'm in the club now!!!
RB24 - GT3076r (.63 IW)
standard head/cams/cam gears set on 0/standard throttle body/standard plenum.
i'm looking into some poncams and hoping to get a bit more out of it.
possible wheelspin up top also??
this was with rev limit at 7200.
rev limit is now at 7500
Edited by huddy
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
