Im bringing my car over the first wek of Feb, fingers crossed with a re-tune and new exhaust ill be pushing out close to 240-250rwkws:) Maybe we dont need the 300cc, but hopefully we dont have wild wheelspin either:)...and fingers crossed it lives and the old $600 RB20 provides plenty of fun:)
heheh.. Not directed at you Roy.. :(
Considering you use your 32 for a lot of track work it does make me wonder if it really is worth building up a motor??? Would you get that much more life out of the rebuilt motor to warrant building it up over cheap second hands. :D
1 rebuilt motor is close to 5-6 second hand motors.
woo up there ice cube..
1. suggestions about my RB24 build.
i have some people to prove wrong.
if i still had my RB25de i would have built a 25/30 a long time ago.
i would love a 30 but i decided to go the 24 route because i just did.
5-6psi more boost will be overcome by higher CR
other than that a 20 sounds better.
DANGEROUS_DAVEO: i prefer beef wrapped in bacon
P.S. MMOOOOOOO
...Considering you use your 32 for a lot of track work it does make me wonder if it really is worth building up a motor??? Would you get that much more life out of the rebuilt motor to warrant building it up over cheap second hands. :(
LOL...its part expense, its part value. The track is great fun whether you are doing 1:30s or 1:26s, so if i keep popping RB20s (I suspect from about Feb onwards all the tomm fullery/butchery will be fixed on my car), so not expecting any more problems.
If the engine croaks then ill at least be comfortable that i know the limits of the RB20...i have my thoughts but thats all they are:(
If you want to go genuinely quick the RB20 can do it. But the dollars dont add up and you have to seriously consider stepping up to a bigger RB. BUT... If you want heaps of fun, and not be living in fear of popping/overheating etc etc an RB26 then RB20s rock:)
Dont have to be the quickest, just wear the biggest smile:) So 6-8 grand to get 3-4 seconds quicker, then i think about how many track days 6grand buys me...lol have you seen Pumping Iron where Arnies talks about lifting weights every day is like cumming...well 6 grand is a sh1t load of track days and i suspect it would have a similar effect on me:)
Im in SA for the next 3 weeks, so bring on Mallala:)
Well said there Roy !!
never really looked at it that way but it makes alot of sense.
with RB20s being cheap there is a big gap between rebuilding and a second hand motor costs.
If we were talking RB26, its a shit load more expensive.
Thing is you could theorectically push the stock bottom end pretty far. I think a few of you guys are accepting that they blow up when making a certin power output. I think with a decent tune, you would make the same power but have the engines last a fair bit longer. And well $600 isnt much compaired to a full proper rebuild, but its still a fair wack of money and a fair bit of time wasted changing over the bottom ends.
Exact thing a mate had problems with, bad tune, didnt change anything but pulled out 2deg of timing and the thing never blew up, same power tho.
I do not know of a single RB20 with around 240-250rwkws that gets driven on street and track...but i agree about the strength of the RB20,
I suppose this year will be the litmus test, though when the mechanic installed the new engine they didnt throw a new timing belt on the car, and there seems to be some idler bearing noise so may change them too...hate to lose an engine because a mishap up front with ancillaries:(
Unfortunately i don't live within 900kms of a race track, so if something does go bang at the track, it is long way to push my car back home.
My motor was fully rebuilt (std)a few months ago. but my dad put a bit of it together, due to my work commitments. anywho, he didn't check the ring gap cause he thought i did, and i hadn't yet. so the end result is low compression in all, and oil in number 1. hence why i want to do it properly this time.
My new list of parts are: Tomei 82mm pistons
Tomei 1mm head gasket
Tomei cam gears X2
HKS GTRs kit
other stuff: Bore engine
new exhaust gasket
gates timing belt
ECU remap
New rear tyres
ROY: idler bearings are $120 for idler $160 for tensioner i think from memory
its turbo i believe, t66/7. Not exactly sure. Built motor such as pistons rods bearings cams plenum ecu inj pump and other little things.
Roy: from the ones i have seen they just get tired after 300rwhp. Blow starts to occur then knocking then you know finish time. A friend had one with over 300rwhp and standard ecu but with a plug in chip, thrashed 24/7 for a good yr then got tired and blow by then knocking then finished.
a mates mate has an R32 and his RB20 has put out 480hp on the dyno... with 30psi and tolulene... but was prolly C16.
thats some bullshit power... i didnt believe it but apparently its spun up 400+hp on a few dyno's so i just dont know.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
