called him to discuss ways about getting it repaired. as soon as he mentioned warranty was void because of the heat wrap thats when i decided to go a different route. but anyway this isnt a thread about bitching i'm looking into what other manifolds are out on the market or even if i can make my own.
  • 9 months later...
its in dyno thread u lazy git haha
stock rb20
walrbo pump
gtr injectors
china cooler and piping
k&n filter
hypergear atr43g3 0.63 rear internal gate standard position
full zaust
nistune
260 @ what psi?
stock rb20
walrbo pump
gtr injectors
k&n filter
full zaust
nistune
Cool, proves you can get a good result with the right parts, not just the name brand parts. Some of the Hypergear turbos are doing a good job on the little CAs and RB20s :)
mmm... Hub is not RWKW when they are no wheels involved. :/
very true, my bad... went on a roller dyno as well but wheel spun and also result seems to be fiddled a little by rival workshop haha
on a side note, first time I have had one of my cars on a hub dyno... while they may read power a little differently, my god it was good not having the head f**k of wheel spin, tyre heat and pressure etc.
so consistant, ran 350hp and then backed up with 351... could not see the difference between the lines
Edited by Cerbera
Mine never gets tied down :)
Ye I've seen some rollers @ times with poorly tied cars and there is just rubber everywhere.
Really makes a mess of the tyres.
You aren't running semi's or something? They = bad for dyno'in.
Nah they are just really shitty rock hard old 245/17's that came with the R33 GTR rims... I mean rock hard as in you do a skid and they don't even smoke haha
The plan was to get tuned on hub dyno, then do a burnout and replace tyres. But we had a chance to put it on a roller and it didn't really work :D
  • 2 months later...
  • 1 month later...
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
