On a 2 litre, yes.  Listen to Roy.
TD06H offers a fair bit more turbine flow than the TDO6S or TD06SL2.  Impeller sizes are roughly 67, 64, 61mm.  The bigger impellers will require more gas flow to get them accelerating.
22 hours ago, Mayby4 said:
I know the longer runners on the standard manifold work great for a street car with torque lower down being better, But I was hoping for slightly better response from shorter ic piping and lower temps as it is a track only car.
and it makes everything so much easier to work on.
I assume the TD06H is a no go due to response?
What DaleFZ1 said. With a small pot 6 cylinder you dont need the TD06H turbine flow to max out the 20G compressor.
I hear you re ther inlet manifold, I ran a Plazmaman and it made more power longer up top but that was over 7,000rpm or something. So is a little disingeinous for me to say it 40rwkws more at 8,000rpm. But it did....but also cost 25-30rwks through the mid
Strangely the car lost top speed down the straight at PI as it smply didnt have the pull in top of 5th even though i was raping it hard into 8,000rpm in 4th before shifting. I was frustrated as the car struggled to pass a 135i with exhaust as according to data i lost a bit on the straight and a few corner exits but gained at a few others. If I had my time again I would go std...which funnily enough my current motor has RB20 architecture and I now run std inlet
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
