blur Posted December 10, 2004 Share Posted December 10, 2004 Just wondering whether anyone has wired up an auto ecu for a silvertop r32 type rb20det at all?? I have been unable to find a pin out for the auto ecu, does anyne know where ill find one?? And if youve done it, how succesful was it? Thanks, Adrian. Link to comment https://www.sau.com.au/forums/topic/58255-has-anyone-wired-up-a-rb20det-auto-ecu-at-all/ Share on other sites More sharing options...
nedb Posted December 10, 2004 Share Posted December 10, 2004 I'm not sure i understand what you're trying to do. Link to comment https://www.sau.com.au/forums/topic/58255-has-anyone-wired-up-a-rb20det-auto-ecu-at-all/#findComment-1117639 Share on other sites More sharing options...
browny Posted December 10, 2004 Share Posted December 10, 2004 Do you want the pinout for the engine control unit or the auto gearbox control unit? If its the former then the manual and auto pinouts are usually on the same diagram, any specific wires for each transmission will be marked accordingly. These are relatively easy to find. If its the latter I might be able to decode my wiring diagrams but I might not be so accurate, and it might take some time. Link to comment https://www.sau.com.au/forums/topic/58255-has-anyone-wired-up-a-rb20det-auto-ecu-at-all/#findComment-1117642 Share on other sites More sharing options...
blur Posted December 10, 2004 Author Share Posted December 10, 2004 i am trying to wire up the auto transmission, its been retro fitted into a r31 skyline along with the silvertop engine.... id like a pin out of an auto ecu if someone has it.. Link to comment https://www.sau.com.au/forums/topic/58255-has-anyone-wired-up-a-rb20det-auto-ecu-at-all/#findComment-1118043 Share on other sites More sharing options...
browny Posted December 10, 2004 Share Posted December 10, 2004 Well since you haven't answered my question, I will assume by ECU you mean the engine control unit. Pinouts here: http://www.rb20det.com/ecupinout.html 4 is missing and should be AAC Valve 6 should be blank The following from the ECU circuits are connected to the A/T control unit: 30 56 48 Pin 3 of throttle valve switch 53 14 5 15 Link to comment https://www.sau.com.au/forums/topic/58255-has-anyone-wired-up-a-rb20det-auto-ecu-at-all/#findComment-1118617 Share on other sites More sharing options...
blur Posted December 10, 2004 Author Share Posted December 10, 2004 i have the engine ecu pinouts.. need the auto ecu pinouts if there available.. Link to comment https://www.sau.com.au/forums/topic/58255-has-anyone-wired-up-a-rb20det-auto-ecu-at-all/#findComment-1118640 Share on other sites More sharing options...
