Typically if you work smart you can actually get a better result cheaper doing/managing the piping install yourself.
If you are not familiar with the piping route then have a look at some HKS/Trust cooler setups, or do a few searches on the forum.
If you are a patient person then you can come up with a much better result, as if a workshop were to take the same care they would have to charge a fortune for their time:(
So my thinking is ring a few exhaust shops and get some prices for 2.5" mild steel bends. You can use the factory pipe from turbo to inner guard, and throttle body to next to timing belt cover...this saves a few bends and dollars and means you can use the std BOV location, but you can replace all the pipes if you want.
You will need 6 (7 will cover it) 90degree bends. You can buy 3 x 180deg bends if its cheaper and you will need about 500mm off cuts of 2.5" tube. About $150 and you should have all the materials.
Taking the front bumper bar off is easy, and so is hole sawing the guard under the battery, just take a bit of care and look at other setups where it is done. Trim the cutout, prime the cutout, or use rust killer etc etc and that is about the most difficult part.
From there just measure, trial fit, cut the bends to get the desired clearances etc etc. When you get the angles right just use plenty of good quality tape to hold the bends together. Black marker to show the alignment of pipe sections helps here to:)
Make sure the fit up of tube ends is tight with no gaps, and the tube which is usually about 1.6mm thick is nice and square. If you have access to a drop saw then great otherwise a hacksaw and file is fine. Make sure any dags and sharp edges ar filed/removed
Once you are satisfied that all the pipe runs are right, then go through the yellow pages and find your local welding shop/boilermakers. Give them a call and tell them you have 10-11 x 2.5" welds to be done.
Say you would like them tig'd and fully purged, and that the pipes are taped/fitted ready for tacking and welding. They will run a blade thru the tape at 2-3 places to reveal the pipe and tack the pipe as orientated by you with the tape. Then they can take all the tap off and weld away.
Try a few places, the smaller niche palces are better and their price vary from a case of beer to 1 hrs work (About $60). Dont get them to dress the welds or anything, you can do all that yourself.
So we are up to around $200 now..plus your time and running around.:D
The welders can also weld lips onto the pipes to stop hoses blowing off, they can roll an edge onto them as well. Rolling the edge is cheaper as its quicker to do, try a few local exhaust shops or metal work places.
Now you just need hose joiners and clamps. Here you can save a few dollars by using you old clamps and black hose. You will most likely need a few extra so can use hydraulic hose from places like Pirtek, again can use off cuts for dirt cheap, or use proper silicon joiners which are a bit pricier.
But with a few new joiners and clamps you are now looking at less then $300. Now with some wet and dry you can give the welds a quick once over and clean up the pipes for a lick of paint, whatever colour you like. So that $15 for paint and clear coat, and wet & dry. You can for about $100-150 have them ceramic coated.
The only thing is chosing the right welding place, as most exhaust shops couldnt weld to save their lives, go to a boilermaker and you have to look twice to see the weld once you have given them a 30 second going over with some wet and dry.
Then again if this all sounds too hard then i have seen nice IC pipework done for around $500-600.
Here is a Piccie of my engine bay. I used stainless and welded it myself as at the time i was fortunate enough to have access to the equip to weld it.
Over my Xmas holidays im actually going to finish polishing my compressor cover and inlet pipe and get it all ceramic coated, then with the rocker covers sitting next to me, my engine bay should look a lot prettier.:D
I’m new to this, I’m in the process of installing an intercooler to my R33 but I would like to use the original piping from the Turbo.
I was going to look at the hardware stores for some piping, maybe alloy, do you think this is a good choice.
Next can I use joiners on both ends of the intercooler and both ends of the piping from the motor or does it have to be welded, I don’t know.
I am going to do this over my holiday were I can work on the car.
Some feedback would be appreciated
Chris G :) :flamed:
Can sell you my HKS piping kit from a HKS Type-S Intercooler Kit for $200, PM if interested.
Like i said in my previous message, Im new to this and i was going to install the intercooler myself over my 6wks holidays. Would it be suitable for a R33, If it is I am interested.
Do you still have the piping and if so were can i send the money.
chris
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
