Hey guys, just need some info. I sold a set of Series 2 or Series 1.5 coil packs to a user on this forum. It was on a spare Series 1 motor that i had. Now apparently, the coilpacks are completely different and i know that it didn't have an ignitor module. It was the way i bought it and need some info on how to fit it on a series 1 motor, so i can help the buyer out.
Also these are for a R33 Skyline with RB25DET.
Thanks.
I'm in the same situation as yourself.
Have s2 coils for a s1 rb25det loom, the plugs dont fit so i was looking at getting hold of series 2 plugs or finding an alternative plug that fits.
Will s2 coils work with a s1 loom and ignitor?
You dont need the s1 ignitor with the s2 coils.
It "should" simply be a matter of tracing the power, earth and signal wires from the s2 coils back to where the s1 ignitor plugs in. There will be 6 wires (for 6 cylinders funnily enough) running direct from the ecu to the s1 ignitor, these are the signal wires that i am assuming have to be directly connected to the s2 coils. The other wires are self explanitary (the pinouts will be written on the coil itself).
I'm not saying it wont pop your ecu though as i don't know if there is any difference between the ignition signal circuitry in the s1 and s2 ecus.
I was thinking of just changing the plugs over on the coil packs but realy want to be sure the series 2 cars still use an ignitor, it must still work the same but be mounted remotly.
With S2 coilpacks Nissan 'built in' the transistors that are found in the ignitor pack found on earlier cars. The ignitor pack on S1's has 6 transistors, one for each of the coil packs. The ECU signals these transistors in turn to fire the coil packs. But on S2's each coil pack has the firing transistors manufactured into the coil pack itself (one per coil pack). The ECU is connected directly to the coil packs on S2's, but the way things work is essentially the same. In theory a S1 ECU should fire S2 coil packs fitted to an S1 engine by simply removing the ignitor pack and 'bridging' the connectors on the wiring loom. Of course if the coil pack connectors are also different you'd have to change them as well.
That said, I've never tried it so take no responsibility if the attempt is made :rolleyes:
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
