Hi, I was wondering what size tyre/wheel combination you guys have employed for your Stagea and how it affected the ride/handling (if any) when using stock springs and struts (if applicable).
I was calculating the change in relative speed to the speedo when choosing different tyre/wheel combinations and came up with the following chart:
W = tyre width in mm
Ra = tyre wall height to width ratio
R = wheel diameter in inches
H = tyre wall height based on Ra
D = approximate tyre diameter in mm
% = percentage of tyre diameter compared to stock (in orange)
60 = real speed when speedo reads 60 kmh
100 = real speed when speedo reads 100 kmh
W	Ra	R	H	D	%	60	100
[COLOR=DarkOrange]205	55	16	113	631.9	100	60	100[/COLOR]
225	50	16	113	631.4	99.92	59.95	99.92
205	40	17	82	595.8	94.29	56.57	94.29
215	40	17	86	603.8	95.55	57.33	95.55
225	45	17	101	634.3	100.38	60.23	100.38
235	45	17	106	643.3	101.80	61.08	101.80
225	45	18	101	659.7	104.40	62.64	104.40
225	40	18	90	637.2	100.84	60.50	100.84
225	35	18	79	614.7	97.28	58.37	97.28
235	40	18	94	645.2	102.10	61.26	102.10
245	40	18	98	653.2	103.37	62.02	103.37
255	35	18	89	635.7	100.60	60.36	100.60
265	35	18	93	642.7	101.71	61.03	101.71
235	35	19	82	647.1	102.41	61.44	102.41
255	40	19	102	686.6	108.66	65.19	108.66
Anyhow, made me curious as to what tyre/wheel combinations peoples were choosing, and what your thoughts are about the combination(s) you have chosen.
Cheers :)
https://www.sau.com.au/forums/topic/58365-what-size-boots-do-you-have-on/
Yepp, that's what I have on mine too. 235/45/17's
But one thing to remember, one brand tyre is usually a different size compared to another, even if they say they are the same size.. :)
I found the ride to be a slight bit firmer compared the the 235/50/16's that I had on before, but not a massive difference.
J
J
That's interesting - that's a fair difference in profile I would have thought - about 12mm by my calculation...
W235 Ra50 R16 H118 D641.4 %101.50 kmh60.90 kmh101.50
perhaps I need to be aiming at a lower profile than I thought...
Cheers :)
  ICE12 said:
Mine came with 225/40ZR18 all round would like to go a little wider when ready for new ones maybe 245 or 255.  As they were already on the car I can't tell you what difference it makes.
:(  ICE
The ride doesn't feel too harsh? I was thinking of going with 225/40R18, but was worried about feeling every bump on the road and tyre noise...
What makes you want to go wider?
Cheers :rofl:
Thanks Ice - I am getting some 235/40/18 fitted on Friday at C-Red tuning (bottom right corner of this link AVS Model 5's: http://www.c-red.com.au/parts/wheels.shtml )
They will also do the sway bars and stuff to tighten up the steering as well. Will look at struts and springs after that if necessary.
Thanks for the info :(
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
