I have a set of tyres that I picked up that look a little like retreads, i.e. a seam around the sidewall near wear the Wear indicator locator is. The tread pattern looks the same though as when I look up the tyre on the internet. Are retreads usually a different tread pattern?
Also the wear indicator locator is just above the seam - i.e in a part that I would have thought would be the retreaded rubber but it has the company design as the locator.
Just dont really want to run Retreads on a skyline.
Thanks
https://www.sau.com.au/forums/topic/58376-how-to-tell-a-retread/
9 times out of ten, a retread company will not find 4 of the same casings.......therefore each tyre has the same tread pattern but different brand names etc on the sidewalls. Whilst this is not ALWAYS accurate it is most of the time.
If they are retreads you will see markings on the sidewalla stating a speed limit for those tyres (normally 140kmph) I belive those markings are required by law.
From what you have said, it seems to me you have good tyres not retreads.
I'm with you :(
No markings on the side so maybe these aren't retreads. Although you can take your tyres to a place and get them retread right? Or do they usually just give you some as swap overs?
I'll take it easy on them anyway as they are a fairly cheap brand.
They're usually different tread patterns, and generally you just give them your old ones and you get new ones..
and from experience with my daily driver and old cars during "I'm poor" school days, and mate's cars they were ok on cheap cars. Generally they start to crack where the new tread is put on after time, which can make them dangerous. Like you say its just the seam line is obvious around the whole tyre, although some tyres from new may have what looks similar I have found.
previous owner put them on my r31.. they held up through a track day, although not much power through them. I was a bit worried they wouldn't (heat build up can cause the tread to separate from the sidewall more than anything else) so had the spare all checked.
But like you're saying - good car + good tyres... change em if you have any doubt.
note: p.s. i can be a psycho :(
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
