Engine specs: FJ20ET
Bore:
89mm
Stroke:
80mm
Bore/Stroke Ratio:
0.898
Engine Weight:
180kg
Compression Ratio:
7.5:1
8:1 (i/cooled)
Horsepower:
188 hp @ 6400 rpm
203Hp @ 6400 RPM (i/cooled)
Torque:
173 ft lb @ 4800 rpm
188 ft/lb @4400 RPM (i/cooled)
Specific Output:
94.5Hp/Litre
102 hp / L (i/cooled)
Factory Boost:
6.5 psi
7.5 psi (i/cooled)
Piston Type:
Cast, unslotted, 2 x 1.5 mm compression rings, 1 x 2.75 mm oil ring
Piston Weight:
545 g
Conrod length:
140 mm c / c
Conrod weight:
880g (raw, unprepped)
Crankshaft:
Forged, fully counterbalanced (same as FJ20E)
Main bearing dia:
54.95 mm
Big end dia:
49.96 mm
Rod/stroke ratio:
1.75
Top ring placement:
6 mm from piston crown
Pin height:
32 mm
Piston dish:
18 cc or
13 cc (i/cooled)
Factory camshafts:
8.75 mm lift,
204° duration @ 0.050" lift
Factory cam timing (lobe c.):
Inlet 112° BTDC
Exhaust 110° BTDC
Fuel injectors:
4 x 375 cc/min,
38 psi fuel pressure reg.
Oil pump configuration:
Straight cut running at crank speed inside front cover (As per FJ20E, but 2 mm wider gears)
Oil pump - recommended max. rpm:
7500 rpm (stock redline)
Combustion Chamber Volume:
49.5cc
Inlet Valve Diameter:
34.5mm
Exhaust Valve Diameter:
30mm
Inlet valve material:
Magnetic head and stem
Exhaust valve material:
Non-magnetic head and stem
Incl. valve angle:
30°
Inlet port area Approx:
14.5 cm2
Exhaust port area Approx:
12.3 cm2
Oxygen sensor:
single wire
Turbo:
Garrett T3, 50 trim compressor, 0.63 A/R turbine (0.48 A/R i/cooled)
https://www.sau.com.au/forums/topic/58392-dr30-rs-x-specs/#findComment-1119817
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
