Turbo 4 sale, for serious drag car. this is a seriously big turbo not for the faint hearted. This TO4B Turbo has a 4 inch intake and a steel wheel. Will comfortably handle 22psi on the road and will push out 800hp on the drag strip.This is a high mount turbo for a skyline and is set up to be used with an external waste gate. This has never been used and has zero play. I have purchased 2 of these when i was in japan expecting that i would break one and i have since figured out that it is impossible. Rec retail price is $4,500. Price for quick sale $2,000 ono if reasonable.
https://www.sau.com.au/forums/topic/58417-to4b-steel-wheel-monster/
ok the make is garret the a/r is 1.14 the exaust wheel is 75mm in diameter, and made of steel. The intake is 4 inches and the compressor is 70mm in diameter the outlet on the compressor is 65mm i hope that helps
pms sent
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
