I just got an EPA notice in the mail....
I have an Apexi Power FC
Boost controller
Pod
Exhaust
Im going to put my silencer back in the exhaust and the stock airbox, do i need to put the stock computer back in?
and how do i reconnect the standard boost solenoid? i realise that there are 3 pipes from the standard boost controller and with the bleed valve i am only using 2 2 of them with one blocked off.
So how do i reconnect it for the EPA test? does anyone have any pics of how it is done?
any help is much appreciated..
https://www.sau.com.au/forums/topic/58436-add-me-to-the-epa-list/
i dont think you have to reconect the standard boost controller, they dont care about your mods only about pollution control, just change your standard computer in and youll be fine, run as little boost as you can and youll pass easy, leave the rest its just a waste of time
it actually depends on the reason u have to go to the EPA...
if its just a noise test u will be ok but a screw in silencer wont pass as they measure without it (screw into the tip that is)
as inark said.... what type of EPA, is it just an exhaust compliance one by the sounds of it.
There is a grave mis-conception about an EPa notice lately. One is nothing more than a waste of 30 mins
Just make the exhaust quieter and go get it tested at an exhaust place licensed to test it.
Dont waste time taking boost controllers off and stuff as thats not what you were EPa'd for and an exhaust shop wont give a shit anyhow
The full inspection is the only time you have to take a fair amount of stuff off (which is unlikely unless a cop pulled you over and went to town on you one night or you've had numerous other EPA notices, which you have not)
This is a first offence but what worries me is that they gave me an appointment to go to the EPA testing centre in Mcleod... Hence why i am asking how to bring the car back to standard.
It is an Air and Noise test the notice states.
Inark: It is just a silencer in the rear muffler with the one srew to secure it, with it in the car is very quiet, so much so that i can bearly hear it so i believe i will be under 90db but i dont know about the legallity of the silencer itself. does it need to be tack welded into place?
I wanted to reconnect the standard boost solenoid just to be sure as it is only a 10 min job but i cant remember the correct way to do so. any ideas?
If the letter suggested you have to go to McLeod for the test, then its a full EPA compliance test.
Therefor, your only allowed ONE intake modification (ie: either a cooler, or pod filter...not both).
No boost controler, no fuel pressure ragulator, no injectors
Basically STOCK
Your silencer plate wont pass...even if you weld the plate in, its no accepted. I know this for fact
You will either have to put the stock exhaust back on (as its close to legal limit as it is) or somehow lower the current system down. Which you probably dont want to do as itll mean resonators/mufflers
Also, dont be sneaky and try to fool the guys up at Mcleod EPA. As they are pretty decentl blokes, they KNOW what to look for especially with Skylines as they get them in on a daily basis
Good Luck
i rang the EPA and was told they will be going over the whole car and as mentioned above, the silencer is illegal however can be welded at the screw but it need to be welded in a way that it cannot be just removed with the tap of a hammer. I suppose it all depends on the tester on the day.
therefore ill leave the front mount and the exhaust but ill have to remove the computer and the boost controller..
Any idea on how to reconnect the standard solenoid?
i had to remove my avcr as well when i got mine tested. I got the boost solenoid removed completely as well as removing the screen. My powerfc was replaced with a stock ecu. They plugged into the diagnostic port to test something and it wouldnt work...so they assumed aftermarket computer. The opened the panel and saw the standard ecu. hehe
[WLDCRD]: if i put the stock ecu in the car and then replace it with the Power FC, does the PFC retain the settings i have or will i have to dyno the car again an tune it again?
from whjat people say, they really know what they are talking about at the EPA testing centre.
anyone have any pics of the stock boost solenoid so i can plug the hoses back up? There are 3 hoses from the standard solenoid, and at the moment with the bleed valve one is blocked, will i have to reconnect it?
']They plugged into the diagnostic port to test something and it wouldnt work...so they assumed aftermarket computer. The opened the panel and saw the standard ecu. hehe
i don't think that they can 'plug something into the diagnostic port' - would they be liable if they fried something? I doubt this is within their 'power'
i certainly wouldn't be letting them do anthing of the sort!
silvar33: powerfc retains all the settings
Ronin 09: yeah they did check it...they go throught near the steering column. They have the plugs! I dont think they alter anything...they just checked.
haha.. I've been shown how to remove and re-fit the AVC-R boost solenoid 3 times and I always forget which hoses go where! Next time someone shows me I think I should be taking notes :rofl:
Thats too bad. To avoid a return trip to EPA and get it sorted in one day you need to do the following;
Apexi PFC - remove, pop in stock ECU.
Boost controller - remove. not allowed because it can change the emissions, even if on stock boost levels
Pod - You are allowed a pod or a FMIC. one or the other not both.
Exhaust - When i go to EPA i have to put on a stock exhaust, my stock Exhaust measured 88dB (stock cat,muffler etc). I've been to EPA and seen guys with exhausts with a baffle plate, they will fail you for 2dB over so save yourself the trouble, get a stock exhaust (can be purchased for $100 roughly, check forums, good investment) and get it bolted on (about $70 from exhaust joint) , or if you want you can do it yourself with a trolley jack...who can be bothered i just pay the $70 and get it done in 30 mins without getting my hands dirty and back/neck sore!
Good luck with it.
']JAPCAB: you can have both pods and front mount if you got a GTR as the fmic is standard and you are allowed one induction mod :)
Not if the intercooler is aftermarket. Standard intercooler and aftermarket pod filters are ok. You can only have aftermarket air filter OR aftermarket intercooler - not both. Personally I think this rule is BULLSHIT, I've got my stock R34 airbox handy just in case I need to swap it over. Although last time I went through a RWC check point they didnt say anything about the 2 induction mods. Maybe cos I'm not on my P's :P
thanks guys...
ill have the car standard apart from the front mount and the exhuast, however i am going to pay the $30 ish for a db test and if it passes ill weld the silencer on as the EPA said this was fine to do so. if it fails ill buy a stock muffler and have them install that.
My only concern in how to reconnect the stock boost solenoid... there are 2 hoses... which 2 are connected together by the T-piece and which one connects to the solenoid on its own? am i right in saying that the hose from the turbo connects to the top of the solenoid and the other 2 hoses are connected together via the T-piece and then to the bottom plug of the solenoid?
I am really desperate for this info as i would assume if it is not connected together it would not meet emissions?
Also, how strict are the emissions? would an R33 GTST with only front mount and full exhaust pass easily?
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
