Hey Guys,
I am sure this has been around before, but I gave up searching for it after 30 mins.
Can someone please tell me the difference between the standard and type M on the R32.
My understanding from maggala is;
- 4 piston brakes.
- bigger turbo (what is the turbo?)
- Stronger LSD (what is the LSD? Is it a 2 2way or anything like that?)
Does HICAS come on all 32's? Only Type M's? Or was it an option on any of them?
Thanks
Chris
https://www.sau.com.au/forums/topic/58461-r32-type-m-whats-the-difference/
Turbo is the same, Yes the larger 4 pot brakes, also 5 stud instead of 4 stud hubs.
Non type m is basically a gts with a turbo motor, so it has the gts suspension as well rather than the gtst suspension eg smaller sway bars etc.
I have an early non-type m and thats pretty much the case.. very small brakes.. but still LSD. Its pretty easy to upgrade the brakes to the 4 pot for pretty cheaply so its no real problem.
Mine has a different steering wheel (not too bad anyhow), no sideskirts, and also has the analogue climate control.
It has HICAS, and I believe if its an R32 of any type, it came with HICAS.
The Type M was the GTS-t marketed at buyers who wanted a GTR but couldn't foot the bill.
Hence it had:
- the GTR style (but narrower) wheels
- 4 spot brakes
- digital climate
- GTR style steering wheel
AFAIK all the GTS-t's has HICAS & Viscous LSD whether they were M's or not
The GTS Type S is the non-turbo equivalent to the Type M
I've got an early 4dr Type M with the extra options of ABS, driving lights, projector headlights & electric front spoiler
r32s with HICAS: gts type s, gts-t, gts-t type m, gts-4 and gtr
gtst has power steering powered system... gts4 and gtr have hydraulic system
download "the sky is the limit" pdf on meggala, this is where i got the above
Thats not true, as I have the "GTR" style wheels and mine is non m-spec.. basically every turbo skyline i have seen has the 5 spoke jobbies.. I have seen them in diagrams with flat style riims, but never seen them over here I don't think.
You have Type M wheels. Mine came with R33 wheels when I bought it, doesn't mean it had them from the factory though :D
Almost (I repeat almost, not all) all R32's imported to Oz will be Type M's (or modified to be like M's). Actually, I think that Type Ms outsold the basic GTS-t when they were new. Funky could prob clear this up for us.
rrrage, whats the diff between powersteering (hydraulic) powerd HICAS & hydraulic? Does the GTR/GTS-4 have a separate system/reservoir? I know that in the GTS-t the HICAS runs off the reservoir in the engine bay... My knowledge of GTR's suck teh arse :P
rrrage, whats the diff between powersteering (hydraulic) powerd HICAS & hydraulic? Does the GTR/GTS-4 have a separate system/reservoir? I know that in the GTS-t the HICAS runs off the reservoir in the engine bay... My knowledge of GTR's suck teh arse :)
good question that, matey. i was quoting this skyline document i printed out, not my own knowledge :P if i come across the info i will contact oyu
