I have the most annoying noise at the moment. ;)
It sounds like a squeeking/bearing noise. The noise stops if i push the clutch even the slightest bit!!!!
Thats great yet i dont want to drive with my clutch in! :mad:
I've been told i can spray some WD40 to shut it up but where would i spray it!!!
Please help as its driving me up the wall. :P:):rant:
https://www.sau.com.au/forums/topic/58472-help/
I had the same noise from mine for a while. You can spray WD40 in where the throwout fork rubber boot is. This is the solid looking arm thing that goes inside the gearbox and moves back and foreward when you push the clutch pedal in an out. If you're unsure, just get someone to operate the clutch and you'll find it pretty quick.
This is only a bandaid cure though. If it keeps up or gets worse then you will have to replace it. They usually start squeaking after a bout of rain. But like grigor said, think aboiut the other things you might need to replace while the gearbox is off as you can save money on labour this way.
https://www.sau.com.au/forums/topic/58472-help/#findComment-1120944
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
    • These things happen And I believe "we, the people, who modify stuff, and actually use it, cannot have nice things" It's just a shame that it happened so soon after paint  I still win the award for quickly destroying newly painted panels I think, as my car came back from the paint shop all nice and shiny, until about 4 hours later when the boot was destroyed by a wayward locker that was blown around by the wind.... What doesn't kill you makes you stronger, and poorer.....dooh
    • This. And also, the rotor thickness is constrained by the calipers. Cannot be much thicker, if at all. Cannot be much thinner, if at all. New rotors are....fairly cheap. Turbo calipers can still be picked up for sensible money. Arguably, the best thing is to get R32 calipers and put them on mount spacers on 324mm discs. That's about the cheapest and easiest way to get quite large brakes that are essentially bolt on. And that's despite maintaining for years that the R32 calipers are not the best choice because they seem to be more flexy and creaky than the others. If you were prepared to put up with nasty little NA sliding calipers, these will still seem like Brembos by comparison.
    • A quick Google said 297mm..
    • Why would you not fit the biggest possible brakes?
