hey guys,
given a few of you are knowledegable about R32s I need help! My car's steering is really heavy like there's no asssistance.
It also won't readily return to centre after a turn, pretty petty but the pits picked it up...... Anyone had any similar problems?
It has a Tomei Hicas lock thing on the side of the computer but this only turns the dash light on and off so I'm guessing its been disabled mechanically. In the engine bay where the pump is there are two wires, I've reconnected one and its turned the dash light off again but still no power steering...
Anyone can help me out I'd be very greatful......
cheers!
https://www.sau.com.au/forums/topic/58500-r32-gts-t-hicas-problems/
  • Replies 40
first check to make sure there is fluid in the reservoir. Then check to make sure the belt is on properly. If these are ok then the pump will need replacement.
The pump is a mechanical pump, not electrical. Even if you disable the hicas completely it still has power steering on the front. Therefore, if it's not pumping then the pump needs replacement. You'll have to do a couple of tests on it before guaranteed stuffed but I'd say that will be your problem if the belt and fluid level are ok.
when I took it to peddars they said the rack was moving on its mounts? I don't have much faith in them though......
My corolla with 300K on it still steers fine so I was surprised that my 100K line had a stuffed one......
think i'll grab a pump and see how I go.... :rofl:
how do you test if the pump is working?
the steering is hard and won't return to centre after a turn on its own, you have to manually bring it back....
If you rev the engine to about 3000 while stationary does the steering become easier or stay the same?
You won't be able to test the pump unless you can somehow check its pressure.
Did it just suddenly go like this? if so...when and what were you doing at the time?
going fast, slow round a corner when you noticed it?
Does the steering make any kind of growling noises when you turn?
Any other types of noises?
or is it just really hard to turn?
See if you can get a pump on there to check it.
Plus, how is the fluid level and the belt?
yeah, the only other thing I can think of...and it's electrical....is the power steer pressure switch. which is right next to one of the pressure lines. Check that it is plugged in.
Don't know how much effect this will have but it shouldn't.
There is a way to test it. It should tell you if your pump is producing enough pressure also.
I'll just read the manual and see if I can find it...I think it's terminal 19 on ecu to ground. Should be 0v when turning. I think...be back in a sec
I re connected a little plug today near the dip stick today. Plugs I have found:
One I reconnected near the pump
One small female tagged to the strut tower not connected
One Big female in front of the strut tower not connected
should either of these two empties be connected?
sorry its so vague, had S13s before this, the line is throwing me :rofl:
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
