  • Replies 40
yeah the one near the pump is the one I re-connected. It made no difference. The other two don't have anything connected to them...
I do have a fuse missing, its labelled "INHIBIT" This supposed to be blank?
thanks heaps for this mate.
the female plugs--are they on the passenger side?
one has a black wire yellow stripe and is right next to the reservior and the other one is on the back of the strut tower and has a yellow wire with a red stripe. They look very similar?
Just wanna make sure these are the plugs you are talking about.
The only ones you have to worry about are the one right next to the res. Not the round grey one but the flat one with the orange head. It comes off the cap of the res. The other wire is round near the dipstick. It should be right in front of the strut tower. Small grey plug two wires. This is the pressure switch.
I'll check the fuse thing
and no worries, glad to help out.
nah these two are on the drivers side. no worries, I guess everythings okay, must be a knackered pump and or rack. I can get both for $250 so I may as well change both.....
thanks a lot mate, helped heaps. It failed pits today for this one reason so as soon as I can get it fixed I can actually drive it!! yay! he he
cheers dude, its been a mini nightmare with this thing. I guess a 15 year old car wouldn't be perfect! so far, new front discs, new pads, bushes, coil packs etc :thumbsup:
ah geez.... I love it though, the RB20 is soooooo much nicer then the SR.....
Damn straight!
yeah man no worries. I did the Hicas test today and sensors 5-9 came back dodgy. I do have a Tomei lock kit so this could be the cause.
On another note, normally on a car with power steering when you turn full lock the pump makes a racket. Mine hardly makes any noise so Im thinkin its pumping days are over....
Is it normal for the Power steering system to pulse during the Hicas test?
I'm pretty sure they do pulse when in diagnostic mode.
if the power steering is functioning correctly then it shouldn't make a racket at full lock.
yeah the speedo does work however it flickers a little at low speed and after 100 or so it sometimes sticks, then jumps to what its supposed to be.
Is the speed sensor the little key thing that goes into the gear box? I took it out yesterday and cleaned it but its still the same.....
reckon this could be the problem? Trouble is, no-one seems to know much about HICAS.
my theory was that maybe the car thinks I'm going faster then I am so the steering is tightening up to compensate..... Maybe I should try another speed sensor?
ummm what does it look like and where is the speed sensor?
That's the speed sensor you were talking about alright.
Mine does the exact same tihng you just said so I don't think tihs is your problem. EXACTLY how hard is it to steer. Is it like XD falcon doin a u turn hard or is it ford laser hatch doin a u turn on 155's hard?
No its not that hard at all, its more the fact of it not self centreing very well. The pit guy said it was too hard, I reckon its just a characteristic of the car, its not an Excel!! he he It doesn't feel much harder then my S13s I've had......
As far as self centreing goes, it doesn't come back fast enough for they're liking. If that's just how the car is though how am i to convince them?
STUPID QUESTION!: I've just had a look at the bearings behind the steering wheel and they're dry as with little bits of metal in there! Could that have an affect?
UPDATE: **** man, this is the dumbest thing known to man. I took the steering wheel surround apart, cleaned the bearings out and re packed them with grease. Steering is fine now, no return to centre problems..... ;)
Thanks heaps dude, you're a champ. :D thank god it wasn't the pump and rack!!!
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
