I have a 32 GTST but they should be the same seeing as though they are the same block.
They should be 14mm nuts (x2). Jack the front of the car up...put it on body stands of course for safety. Go in behind the drivers front wheel under the car. You should be able to easily access the lower bolt from here. The top bolt is a lot more tricky. You'll have to get at it from the top and use a 3/8 drive rachet and 14mm socket. I'm pretty sure the 33 is the same but the heater hoses mount to the top bolt on the 32 so make sure you put it back the same way. REMEMBER...ALWAYS DISCONNECT YOUR BATTERY FIRST BEFORE REMOVING STARTER MOTORS OR ALTERNATORS. Disconnect the battery even before you jack up the car. Just for safety.
