im in cairns and it's never happend to me it gets blody hot here
Yeah mate, figured no-one else had this problem... Its f#$&^d!!!
Just hoping that someone knew wat was going on - considering this is a Skyline website and ppl CLAIM to know wat they are talking about!!
Thanx anyway.
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1126940
Your car is fu(ked, :P
Yeah thanks for that... Just in case i didnt know!!!
Besides the blatently obvious of it being a pain in the ass, the fact that ppl look at Skylines and it stalls just about anywhere makes it a bitch to go anywhere without having every1 laugh at ya!!! Fun and games hey??
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1127305
this problem was happening with my soarer, and I realised that it was my amp power wire had got melted over the back seat, and was shorting out.
I guess try to look at all obvious things - check wiring, batt terminals etc
Yeah had thought of that but when it turns off the electrics stay on so it wouldn't be a short...
Had about 1001 ideas of wat it could be but so far nothing, revs used 2 be unstable 2, changing between 300 - 2100 all the time, so i thought the turning off could have been related but found that the idle problem was just an average attempt to re-connect the RPM wire!!!
Thanks for your suggestion anyway.
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1127320
Sorry guys - probably 2 vague, but was pretty sceptical from the start...
Alright this is what we're talking about:-
It has turned off while cruising or idiling - these 2 are the most common.
But it also has occasionally turned off on takeoff, or breaking hard!
The only time it NEVER turns off is when i'm really giving it to it.
It also seems to flat spot (if that's what you'd call it) i'll be driving along and it just stops responding for maybe 1 or 2 seconds, no matter how far the accelerator is down it does nothing, then it will kick back and keep going - it almost seems like it is trying to turn off... If it does this a couple of times, all i have to do is put it in Neutral while driving along and the revs drop to 0 and she turns off.
Electrics stay on though so i've ruled out a short, it also starts up straight away 2.
Another thing that it does is if I'm driving on a warmish - hot day, the flat spotting will occur and if i can manage to keep it on, the next time i go to drive it (no matter how long it is after it) it plays up, almost like its got a memory (thats where i was thinking the ECU)
It's very common during the warmer weather, almost unheard of during the colder - and its pretty much got me fu$&@d...
That's about it...
Hope this helps, if u need anymore info let me know...
Thanks all!!
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1127534
it sounds like something i read on the forum about the fuel pump earth or sumthing shorting out.. finding the earth and reconnect it in a better location.. worth a shot. also check that your spark plugs are screwd in nice and tight.. disconnect and connect your battery after you try it.. hope this helps.
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1127544
I'm no expert, but have you checked for leaks along the intake system? If unmetered air is getting into the system after the AFM, then that could make it run shit. A celica I owned had a crack in the intake plumbing and the bastard would not idle, almost dying all the time and bunny-hopped on take off.
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1127554
    • Definitely didn't put a N/A cluster in instead? The speed sensor (location) is different in both cars.... I think. This will obviously stuff things up.
    • Nah not the throwout bearing, it's something internal. I already replaced the throwout bearing. Mechanic misdiagnosed my car and thought it was a spigot bearing, went to another bloke who said it was an input shaft bearing. (I replaced everything when I pulled out the gearbox but didn't open up the gearbox.   In this video at timestamp 6:05 : Mine has the same sound  min
    • It is definitely to space it out and away for clearance during compression, and possibly for spring clearance to upper arm. That latter would only be true for springs that are same-ish diameter to stockers, and so that probably doesn't apply to Teins or most other coilovers.
    • Yeah, a mechanic who knows these cars told me even if I get a brand new gearbox the noise will return but will be less noticeable. I've heard someone also they this noise came back after 3,000km on a new or reconditioned gearbox. It is pretty f**king annoying though just hearing groaning most of the time lol. I wonder if an aftermarket input shaft bearing would fix the problem or how they are built.
    • All RB gearbags, especially the big turbo box, have rollover noise. Mine certainly does. Always has. Sometimes is worse than others - no particular idea why, although it is probably temperature related. I have smurf jizz in mine and have had to have it in there from the first day the box went into teh car. It simply would not select gears with the engine on, on day one, with normal oil in there. And so, the blue stuff has probably ruined almost everything synchro related in the box. But it has taken 12 or 13 years to get to the point where I simply must replace the box. It has become increasingly baulky of late, which might be symptomatic of the way I've been driving it, as much as anything. I shall have to make some corrections when teh new box goes in. Input shaft bearing noise will decrease with clutch pedal pressed because the drive is removed. But yes, more often than not noises that work like that are associated with the throwout. It won't matter either way, new box will mean this one can be relegated to the parts pile.
