im in cairns and it's never happend to me it gets blody hot here
Yeah mate, figured no-one else had this problem... Its f#$&^d!!!
Just hoping that someone knew wat was going on - considering this is a Skyline website and ppl CLAIM to know wat they are talking about!!
Thanx anyway.
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1126940
Your car is fu(ked, :P
Yeah thanks for that... Just in case i didnt know!!!
Besides the blatently obvious of it being a pain in the ass, the fact that ppl look at Skylines and it stalls just about anywhere makes it a bitch to go anywhere without having every1 laugh at ya!!! Fun and games hey??
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1127305
this problem was happening with my soarer, and I realised that it was my amp power wire had got melted over the back seat, and was shorting out.
I guess try to look at all obvious things - check wiring, batt terminals etc
Yeah had thought of that but when it turns off the electrics stay on so it wouldn't be a short...
Had about 1001 ideas of wat it could be but so far nothing, revs used 2 be unstable 2, changing between 300 - 2100 all the time, so i thought the turning off could have been related but found that the idle problem was just an average attempt to re-connect the RPM wire!!!
Thanks for your suggestion anyway.
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1127320
Sorry guys - probably 2 vague, but was pretty sceptical from the start...
Alright this is what we're talking about:-
It has turned off while cruising or idiling - these 2 are the most common.
But it also has occasionally turned off on takeoff, or breaking hard!
The only time it NEVER turns off is when i'm really giving it to it.
It also seems to flat spot (if that's what you'd call it) i'll be driving along and it just stops responding for maybe 1 or 2 seconds, no matter how far the accelerator is down it does nothing, then it will kick back and keep going - it almost seems like it is trying to turn off... If it does this a couple of times, all i have to do is put it in Neutral while driving along and the revs drop to 0 and she turns off.
Electrics stay on though so i've ruled out a short, it also starts up straight away 2.
Another thing that it does is if I'm driving on a warmish - hot day, the flat spotting will occur and if i can manage to keep it on, the next time i go to drive it (no matter how long it is after it) it plays up, almost like its got a memory (thats where i was thinking the ECU)
It's very common during the warmer weather, almost unheard of during the colder - and its pretty much got me fu$&@d...
That's about it...
Hope this helps, if u need anymore info let me know...
Thanks all!!
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1127534
it sounds like something i read on the forum about the fuel pump earth or sumthing shorting out.. finding the earth and reconnect it in a better location.. worth a shot. also check that your spark plugs are screwd in nice and tight.. disconnect and connect your battery after you try it.. hope this helps.
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1127544
I'm no expert, but have you checked for leaks along the intake system? If unmetered air is getting into the system after the AFM, then that could make it run shit. A celica I owned had a crack in the intake plumbing and the bastard would not idle, almost dying all the time and bunny-hopped on take off.
https://www.sau.com.au/forums/topic/58517-r33-turning-off/#findComment-1127554
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
