Thought I would start a Stagea Intercooler thread, so here goes
The stock Intercooler placement is CR*P, and so relocation/replacement is
a viable option
I see lots of 600x300x76 coolers, is there enough room for one of these
or is a 2nd hand GTR cooler a better bet.
Any hints on piping etc, how easy to do
Many thanks
https://www.sau.com.au/forums/topic/58586-stagea-intercoolers/
Enough room for a GTR cooler - fills up the front bar nicely. About 25% of it is wasted though - sits up quite high. I would recommend a second hand gtr cooler - excellent flow.
Ken
Ken
Cool
How difiicult to fabricate/route the piping (no cutting of panels I hope :Oops:
A hole saw is need for the box under the battery, you need a hole there to run the piping. Be prepared to find a new washer bottle too - that gets in the way. You are probably better off getting a r33 ic kit, should bolt up without a problem.
Cheers,
Ken
Depending on your power goal, Trust make an replacement intercooler that sits in the stock location.
Three times the thickness, MUCH better end tank design, and it flows heaps better too.
I'm not sure how much power it will support, but if your after a mild setup it might be worth looking at (secondhand). You may be able to pick one up for the cost of just the pipework on a FMIC.
J
 J
Now THAT sounds like a plan. I'm interested in anyone that has a lead on one of these units.
Based on the Trust website, there is no specific Stagea cooler, but there are genuine replacements for the R33 & 34. I was under the impression that the C34 intercooler mounting is the same as R34. Can anyone clarify that?
I can clarify that the R33 GTS-t Trust side mount intercooler is a near perfect fit on a 96/97 Stagea cause that's what's on mine at the moment.
The top and back mounting points line up perfectly, although the front mounting point doesn't cause the Stagea's tow hooks are located further rearward compared the the R33's. Although the two mounting points (the top one in particular) makes it very secure. Remember that the two hoses help hold the cooler there too.
The only other thing I had to do was trim about one inch of plastic off the inside of the front bar. Mind you, when you put the black plastic wheel arch thing in you can't even see where I trimmed the plastic !!
I noticed a noticable difference in responce and power when I put it in. I wouldn't say it gave me a million kw at the wheels, but there was a definate difference.
J
J
Hi J, was the standard Stagea intercooler the same as a R33GTST or R34GTT?;)
Mercury Motorsport just fitted a FMIC to the stagea. Fits behind the grill without any choping into it. The only thing they had to do was take a little slice out of the re-enforcing bar. They did a damn good job.
Cheers
Gary
The 'cheap' upgrade I read about was to fit the 25GTT cooler as it was a better design than the GTS25T unit. FYI, the Trust webby with all the models available is: http://babelfish.altavista.com/babelfish/t...cooler_kit.html
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
