What do you think about reverse flow FMIC piping on GTST's
What I mean is to come out of the turbo, across the top of the radiator down thru RH inner guard, thru intercooler and return thru LH inner guard using the factory intercooler hole and up to the engine crossover pipe.
The advantage is less heat soak to the intercooler pipng from the intercooler to engine. This will end up having the same amount of heat soak to the piping as the factory piping did
https://www.sau.com.au/forums/topic/58589-reverse-flow-fmic-piping-on-gtsts/
sounds like a good idea, no idea on the thermodynamics flow side of it. you would also have lesss bends before the input side as normally you need about 2 or 3 wide bends to get back to the plenum, whereas you only have 1 main bend which is from the outlet side to plenum inlet side, as the rest are just soft curves
i had my piping setup this way, works well and the pipe from the cooler to plenum doesn't get that hot.
this way you can also keep the pipe diameter 3" from the cooler outlet to the intake plenum if you want.
pic here
  • 1 month later...
  • 11 months later...
Mine is setup so that it uses the stock piping route.
The hot air comes out of the turbo down in to the front bumper via the stock piping route, it then runs below and slightly behind the FMIC which then does 2 90 degree bends in to the FMIC (drivers side), the tank has the inlet positioned in the center of the core.
The cool air then travels out of the fmic via a very short route back in to the stock piping and thats it :P
Touching the turbo out piping, its damn hot almost too hot to touch. :S
The turbo is pushed to its limits BUT the fmic is definitely doing its job as you can feel the inlet side tank being hot then over the core it gradually becomes cold to touch, the outlet tank and piping is cold, apart from the engine cross over pipe obviously.
Both methods have exactly the same amount of 90 degree bends so they should flow exactly the same, the across the engine bay does have a slightly shorter turbo outlet distance.
Hope that makes sense.. I was up at 3am this morning. :S
Edited by Cubes
i have a fairly cheap FMIC kit and the piping that come from the cooler to the inlet manifold gets hots i was just wondering if heat wrap would help? i know most ppl say it keeps heat in not out but there shouldn't be any heat in the pipes so instead it will just stop heat getting in. The outlet side of the FMIC feels nice and cold after a drive but that pipe gets hot
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
