Wanted r33 Non turbo
I have a non turbo 1996 Series 2 R33 for sale;
Metallic silver
46,000km
5 speed manual
HICAS
Dual airbags
Climate Control
Alarm/immobiliser
Clarion CD Player
16" ANZ spoke rims
2.5" exhaust, 4" tip
Blitz Air Filter
Lowered springs
Tinted Windows
Immaculate inside and out
$19,500 firm
ps. your email bounced back? so im posting here.
https://www.sau.com.au/forums/topic/586-wanted-r33-non-turbo/#findComment-16082
pics and specs of r33 non turbo gts
this car can be put on the road at $16,000 registered and roadworthy, with
complianced, all done drive away
specs
car is a grade 4 where 4.5 is best possible grading at auctions
1994 model
manual
2.5 litre 6
57,300kms
sports steering wheel
aftermarket sports exhaust system
stereo-mini disk player and cd player
climate control
full electrics
tinted windows in rears
non accident vehicle
these are the pics of the car in Japan
if interested e-mail me back
this car can be done for $16,000 on the road in your name
[email protected]
https://www.sau.com.au/forums/topic/586-wanted-r33-non-turbo/#findComment-22727
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
