OK so who is the one who lost 2 a sportivo!!!
MegaGTS4
 Share
  • Replies 76
The last corolla i came up against was the boxie style 1989 corolla (usually the 100kw 4age engine) he had 4 guys in the car, he asked me to give him a run and said why not, and to my surprise i heard i BOV go off and thought wtf? he kept up with me til 100, i was the only person in the car with approx 180rwkw, then i talked to him and he said he was running a MR2 engine, then i thought okay that explains it. hahah
you never know what your up against til you see results, another time i was in friends stock a block evo 6 1/2 and a ricer 2 door 99 model lancer came up to us FULL STEALTH i swear heard the HKS SSQV go off, and thought HUH? up to 100 he kept up even off launch then after that he blew us away , did some research and discovered that he was running a evo engine with a big ass turbo aiii...........
my 2cents worth of past experiences
I reckon it's cool to see a micro machine move, but not brag about it.
If the Corrola had same serious TRD go fast bits even NA, they can catch you by surprise...aren't they 1170kg only! They are over here.
210ps/20.4kgm!
Yes, there is always someone faster. Which is even harder to guess with cars over here. Once along the wangan on the way to the drags a Daihatsu Opti with 3 passengers onboard continually toyed with both an E3 and 180SX. :):D:D
I'm sure the Opti had some serious work done to it...660cc can only go so fast :P.
Yeah, two of my mates have/had 3sgte corollas. Quite quick cars, pulled on my car, and I beat most of the r32s I challenge on the track..... So this one nite, out and about at umm Queensland raceway... We came across a celica (same engine as the sportivo corollas yeah?) Anyway end of the day this thing was next to us up to about 160kmh odd, and it had a few small things done to it.
Id belive one could beat a skyline.
"I had a run with a r33 gtst a while ago. My stivo was stock as a rock. Guy pulled up beside me in the skyline and did the usual creeping forward manouvere but when the light went green I basically held him thru 1st, pulled right up on him in 2nd, he pulled a bit on me with his 2nd and I grabbed 3rd and backed off at about 140 to make a left turn and he had about a mudguard on me. Hmmm where is he now that I've got a few more goddies under the hood..."
sad sad sad...
stock vs 33gtst and he only gets a mud guard on him
Hmm I don’t doubt the corolla would have put in a good effort…my old 4AGE could be quite surprising when you sat on the revs just before the cams kicked in.
The only thing I’ve found with the corollas is the torque just doesn’t feel like it’s there…don’t get me wrong they rev like hell, have some reasonable power…they just can’t get the thing moving, from 0-4000rpm they’re quite unremarkable.
With a pod and an exhaust my car when it was N/A could take them, so this 32 owner can’t drive :P
Saying that though….on some ‘magna forum’ some guy is probably gloating about the R34 he kept up with last night. I took off in 2nd, didn’t go past 4000rpm and he was revving the balls of this thing trying to get past me.
whats this LIFT they all talking about between gear changes , is this the new V-tec thingy for toyota's
Yep, they've got all the usual continuous VVT that you get on any VVTi car, but also VTEC like lift adjustment. Not sure how they do it exactly, but the result is pretty similar to VTEC. Have a look on the side of a new Celica, you'll see VVTLi on it with the L in red.
210ps/20.4kgm!
We certainly get a much more watered down version than that here. That has about the same power as an R32 GTSt, which is insane when you consider that it is just a NA 1.8L.
MIC33R - Hate to go off topic, but is the dude in your av the thing from spirited away ?
Yep, that's him. He's called "No Face".
I loved the movie for some reason. I'm normally not too keen on anime, but this one I just really liked.
Some of the worked V-tech Hondas you see getting round our pretty quick,
fit a better flowing intake and exhaust, shave the head for more compression, more agressive cams, fit a programable ecu and strip as much weight out of the car as you can and you can get them to run 13's.
So if you do the same sort of work to a sportivo there's no reason why you shouldn't be able to go as quick, so being able to beat a stock r32 gts ot gtst really isn't that unbeilivable.
rode passenger in an IS200 or whatever its called with the custom Beams 3SGE engine in it, and it rev's like a biotch. I was curious about the engine to put into my AE86, so the owner volunteered to let me ride along to see how it went... feels just as good as a turbo i reckon... so awesome esp when going around corners as you can just keep your foot down and let it rev its heart out.
that's the beauty of an NA engine, you can rev like mad around corners without lag.
Shan - what's a VSII?
 Share
    • this explains the possibility of several maps with different boost levels
    • ok, I understand much better how we can control the boost and increase the number of psi before opening the wastegate
    • Well.... yes and perhaps no. It depends on what you mean by "spool". For most of us, the point that we would describe as where the turbo is "spooling" is the point where the wheel speed gets high enough for it to start making some boost. This is coincidentally around about the point where it starts making noise - hence the "spooling" sound. If that is what you mean, then no - the wastegate should still be shut at this point. The boost will still be way below the point where it should start opening. If, on the other hand, you mean "spool" as "reach full boost", then yes. At the point where the boost has reached target, then boost control has already started. The wastegate is already open, and has been for some time. Some short time, definitely, but still, some time. If you have no boost controller - just the wastegate actuator connected to the boost source, then you have a mechanical system working as a pressure balance. There is pressure on one side of the wastegate actuator's diaphragm from the spring, and pressure on the other side coming from the boost measurement location (the "source"). This is not a digital thing. The wastegate does not stay shut until the boost pressure reaches the spring "pressure". The spring will start to compress as soon as you start to apply any pressure onto it. This can be controlled somewhat by adding pre-load into the spring, but you cannot add enough preload to make it into a digital switch behaviour. The wastegate will crack open and start to leak exhaust out (and therefore not though the turbine) well before you reach the target boost pressure. Electronic (and some mechanical/pneumatic) boost controllers will act to prevent the boost source applying pressure to the actuator until just before you reach target boost, thus preventing the wastegate from creeping open. And some boost controllers will apply boost pressure on the spring side to further push it shut. And this can be be necessary because the exhaust pressure in the manifold also pushes on the wastegate valve and tries to open it and you cab get it leaking even without it being connected to the boost source.
    • A stand alone boost controller will not give you the control you need, unlike a modern ECU. Your boost will always naturally target the wastegate's opening pressure first, your controller then will allow you to add more boost as required.
    • I recently discovered that I could not remove the outer bolt on one of my rear UCAs. Looked like it was seized to the crush tube. It wasn't all that long since I had last had that arm out (I dunno exactly, but certainly <2 yrs), so I was a bit surprised. I thought I had stock bushes in the rear knuckles, so I ordered some new PU bushes and resigned myself to having to do some dismantlery....and some butchery. It was clear that the seized bush was going to need to have the bolt cut out of it and then possibly some more brutality after that. Upon getting the 3x arms on each side disconnected from the knuckles (with the exception of the seized one, of course), I discovered that I had in fact put PU bushes into the knuckles when I did the subframe conversion about 12-13 years ago. So, I say "Oh, good, I might not have to swap any of these others out". We set to work butchering the bolt out of the seized arm. Stainless blade in a big-arse Milwaukee recipro made short work of it, and also damaged the arm, which added a welding and grinding and painting step to the whole exercise. During the butchery it became clear that the bolt was not just seized but bent. Head scratching ensued, as it is hard to understand how that bolt could get bent. I did suffer a broken (stock) toe control arm on that side a few months ago, and drove some miles with some significant rear wheel self steer and lack of control, which probably was the cause. But it's still hard to understand how it would bend that bolt, rather than just bend the arm. But here's the start of the real discoveries. The crush tube was rusty as all shit. I mean seriously rusty. A little on the inside, contributing to the tube seizing to the bolt (along with the bend). But the outside had at least 2-3mm of compressed flaky iron oxide jammed in between the parent metal and the PU bush. This one was brutalised and still took some effort to get the PU off the crush tube. So I thought I'd inspect the others more closely. The one on the tension rod adjacent the bent one was first. I had to use a 2-jaw puller to get the crush tube out, and it took some effort. It came out looking like the first one. All 6 of them were the same, except for one that looked not too bad. Had some corrosion on it, but was mostly OK. There was also a significant amount of corrosion on the inner surfaces of the knuckles. They took some convincing with pointy tools to let go their grip on the inside of the holes they were in. There was no sign of the original (SuperPro) lube anywhere. I and my bro-in-law have never seen any crush tube end up looking like this. It was seriously like the car has spent time putting boats into the water at the boat ramp. So, it seems like the PU might have been bonded to the steel on both sides, which would have to make them work more like stock rubber bushes (where arm deflection results in twist inside the rubber). Despite this, I have never had cause to believe that they were so tightly bound up. The suspension moved up and down much as you'd expect. The car never made any noises in those bushes that would have led me to believe there was a problem. Maybe the rusty interfaces actually were "sliding". Anyway, lesson learnt. Even quiet, non-troublesome PU bushes should be inspected every now and then!
