Nissan 1993 Skyline GTST M-Spec
RB20DET
Gunmetal Grey
Manual
GTR front grille
GTR Bonnet
3" Exhuast pipe Turbo back with Apexi Dunk muffler
Apexi Twin Chamber BOV
Bleed Valve set at 12psi
Apexi mesh Pod filter
R33 GTR intercooler with Alloy piping
R33 GTR fuel pump
Tein Shocks / Height adjustable.
Power FC with hand controller / Tuned.
Blitz Turbo timer
Greedy boost guage with Greedy A-Pillar
JVC head Unit / Infinity Splits
Tuned & does 162RWKW
Only minor problems are:
few scratches on body work.
Battery leaked so engine bay aint as good as it use to be. (been quoted $250 to resprey)
Great project car, just need a turbo a few minor stuff to hit 200kw
Reason for seling?...well i want a newier car, if anyone can offer a trade + cash on my part i will be interested also. lookin for car 1999+
After $14k
If car sold at $14k will throw in (which have not been installed on my car)
Oz-giken twin plate clutch (80% meat left on plate)
550cc Denzo injectors
Cusco Oil Catch can
***SOLD***
https://www.sau.com.au/forums/topic/58638-nissan-93-r32-gtst/
hey man where abouts are you located in sydney? a mate of mine is looking to buy an r32 and this sounds like the exact one he is after. how many kms on the clock
got any pics ??
where abouts are you located ??
how many kms ??
how often is it serviced ??
timing belt changed recent or not ??
interior in good condition ??
No recent pics...If you really want pics i will take some this weekend.
Located in Fairfield area
K's well thats a very interesting question....I got the car 2 years ago on 40 000 k on the clock & its got 67 000 now
I know for a 11yr old car k's to be that low or even impossible, i dont beleive it myself i think the owner in japan had a Nismo cluster before he sold he it wacked on the factory one...theres no sign of a clock back after i took it to a mechanic. Never had 1 mechnical problem with the car at all.
Change Mobil 1 + spark plugs every 5000k without fail....
Timing belt hasnt been changed since i got it, i dont drive it very often & i dont hear any noise coming from that area.
Interior is Top condition very clean, i very rarely have more then 2 people in the car.
also i got a momo steering wheel i will throw in also if sold at $14k
more pics:
engine bay (which isnt included on my website)
& the battery leak disaster
as you can see the overall engine bay is in top condition, just where the battery leaked, nothing major just a bit of surface rust but thats easilly fixed.
Very interested in your car. Unfourtunately pics wouldn't work for me so just wondering if it has a set of aftermarket wheels, does it have side skirts and does it have a sunroof. Where abouts in Sydney you located, I'm near olympic park and would like to have a look A.S.A.P
Factory Rims
Factory side skits (Type M)
No Sunroof.
I live in the Fairfield area...near Parramatta.
PHATGTR: if the pics aint working for you, try to install Micromedia flash.
if you cant be bother send me your email address & ill email them to you once i get back from work.
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
