I am presently considering how to go about changing the diff ratio in the R32 GTR from the 4.11 to 4.375. Don't care for the top end or fuel ecconomy it's a work car.
I am aware that the front and rear diffs need to be swapped and I am wondering about the easiest way to go about getting it all happening.
I have heard that diff centers from various skylines are compatible I'd like to know from people exactly which ones are bolt in. Also from another angle how hard the ring and pinion are to change and what centres are compatible there.
The GTS4's diff (4.375) in the RB20 swapped straight over into the RB25DET Stagea engine I fitted.
The front suspension needs to be almost pulled apart, because you need to extract the RH drive shaft before you can remove the diff. (the LH is not quite as involved)
The torque setting on the pinion retaining nut is "VFT". You will need a BBIIGG socket and a LLOONNGG breaker bar to undo it.
Front and rear diff centre from the r32 gtr are mechanical already, so just get the clutch packs tightened up. Put the gtr centres in an existing GTS4 front diff and rear diff and voila!
Any centre that fits the r32 gtr will fit an r32 gts4 :P
Take note of the fuel economy difference Rev..
I am considering the swap from 4.363:1 to 4.11:1.
Fuel economy being a factor + the 3ltr tends to rev too quick through the gears when accelerating lightly, first being the biggest pain in the arse.
Hi Rev;
I trust you have done your homework on this and worked out speeds in gears etc. With an already short first gear in the GTR it's going to shorten it's legs further and for a work car - assume daily driven? - that might be annoying. I was actually considering going the other way to a taller final drive as an RB26 with minor mods prob has the grunt to cope. I understand Mercedes is going from 5 to 4 speed autos in thier big hitters because they have the torque to cope with it. No point changing gears unless you have to.
Just my 2c.
Regards.
Hi Rev;
Just my 2c.
Regards.
GTR first short gear ?? They have a very tall first gear pulling over 60k;s out of first.
Hi Rev;
Just my 2c.
Regards.
Hi,
The first part of my post reffers to my care factor about the fuel ecconomy, thanks for the concern tho'.
When you own a GTR I think fuel ecconomy has to be very low on the priority. My car is used for work and does 30,000kms+/year but, it's expenses (inc. fuel) are paid by a car allowance. If I cared about fuel ecconmony I would have bought a scooter.
Rev,
Just out of curiosity's sake would you mind taking note if it does indeed change the fuel economy for the better or worse?
A nice example of a higher diff ratio returning better fuel economy is the R13 Skyline's 3.7:1 vs the VL Commodore 3.45:1.
Around locally the R31 returns better fuel economy then on the open road the VL returns better.
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
