  • Replies 83
fjs r good motors and respond realy well 2 mods, a mate has a ra40 celica with a fj20det its a stock engine with ems,fmi,3",t04 on 10psi and made 310 rwhp no shit, its ran a low 13,
i own a z18et bluebird and a rb30e(soon et ) r31, as much as i like the skyline people expect them 2b fast but if u want 2piss people off beat them in a bluey :flamed:
up the bluey
p.s. this is pro910 logged in as hr31_rb20det
History of the FJ20.
Nissan were on the verge of greenlighting an F1 campaign in the early 80's, when F1 was small displacement engines running ridiculous boost levels. The FJ20 started life as the FJ15, and was designed to cope with power levels approaching 1000bhp, not bad for a 1.5 litre four.
Nissan pulled out at the last minute, and with millions of $$ R&D invested in the programme
(and tooling), stretched the capacity to two litres & fitted them to DR30 Skylines.
So the FJ20 is one VERY serious motor. Yes the SR20 is lighter, but serious horsepower freaks know that the FJ is tha shizzle.
Anyone remember Jeff Watsons FJ20 drag Sprite ?
for starters weight does play a large part in any forward motion regardless, if you have two cars with the same rough power output but 200Kg weight difference whos going to be faster, everyone knows the difference between just them in there car and when your mates are there too, the only true way to see which is better is in a controled enviroment.
EVL032 bad luck mate!!
nothing wrong with both motors, each to there own, also there are a few fj24det's out there.
I've been in a Gemini that cost about $5000 all up, only has 198hp at the wheels, and would munch a Skyline any day of the week!
thats nice, but as i said you put 4 mates in the same gemi and see how well it goes.... my skyline weighs in around 1150KG with the rb20det in it you put it next to a r32 with the same mods and mine will be in front!
at the end of the day the post i started will finally be resovlved with the fj20 i raced getting a dyno today so i will see what he had! i will get mine onced the T3/T4e goes on n we see how the Rb20 pans out once the turbo is on i think the forges will help me run higher boost safl;y so y he beat me in the FJ yes my car is reliable so iam happy!!!!!
sorry boys but it proves my point that i was right cause a mate with an FJ made 157rwkw and this guy with a microtec exhaust n FMIC makes 180rwkw.
thats one to me see it has more than he was saying yeh sorry thats just me boasting that i was right me = happy now
MERRY XMAS ALL
no iam not actually i would rather the RB20det. parts r easyer to obtain....BUT if u actually read the original post u would see that we were arging wheather it was just a FJ20 with microtec, xhaust, FMIC now at 180RWKW that proves i was right no way is that an FJ20 with only those mods.....sooo yes i was right
can any1 confirm that a stock fj motor with 15psi , microtech, fmic, exhaust, air intake. can make 180rwkw?!
Right first is first...NOE is not that way to spell KNOW or NO.....
An FJ20 with those mods will make that sorta power, the biggest power restictor on an FJ is the standard ECU/airflow meter....180rwkw is not outta veiw of an FJ with those mods
    • Thanks! Will get it looked at before winter 🥶 other than that she's a mint ride love it aye
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
