yeah theres definately a few around... there was one i wanted to buy from japan as it had an RB26DETT in it...
i would have to say it would be different but im still looking... will try and confirm.
https://www.sau.com.au/forums/topic/58726-na31-cefiro/#findComment-1124044
Here is some info I have on the Cefiros. Some even came with RB25DET goodness. 4WD was RB20DET.
8809 - 9008 - RB20DET 2WD
9008 - unknown - RB20DET 4WD
9206 - unknown - RB25DE 2WD
More Pictures like the one below can be found at http://www.innaloo.net/~jai/cefiro/fast/
JK
https://www.sau.com.au/forums/topic/58726-na31-cefiro/#findComment-1124078
Thanks for the info mate.
Ok, now the question is,..is it possible to fit all the R32 GTR Drivetrain into an A31(RWD) chassis?
From my understanding the A31's front suspension is McPherson type and the GTR is multi-link,which means they have different suspension pick up points hence a different crossmember.
I may be wrong so feel free to correct me.
https://www.sau.com.au/forums/topic/58726-na31-cefiro/#findComment-1124111
The AWD ceffies are the floowing:
Nissan Cefiro 2.0 ATESSA Cruise Model released August, 1990
Nissan Cefiro 2.0 ATESSA Cruise Model released August, 1991
Nissan Cefiro 2.0 SE-4 Model release May, 1992
The SE-4's sucky as, wheras the ATESSA Cruise are the puppies you wanna get.
https://www.sau.com.au/forums/topic/58726-na31-cefiro/#findComment-1124145
you'll have to replace all the sensors with proper GTR ones, fit some hicas equipment as most ceffies didn't come with hicas (was only an option). other than that, the ATESSA system in the A31 is very similar to the one in the GTS4, not the GTR's ATESSA. net result the car feels bulky and is less maneuvreble than a RWD car, or a GTR.
Novel idea tho.
https://www.sau.com.au/forums/topic/58726-na31-cefiro/#findComment-1124217
i'd say its very similar to making a GTS4 into a GTR. in other words, waste of time n money. keep it RWD and make it more fun. If you really need to spend your money that badly on a GTR with 4 doors, buy a 260RS. It runs a similar setup to what a GTR-Spec ATESSA AWD Cefiro will be like, out of the box. SHould end up costing around the same too.
https://www.sau.com.au/forums/topic/58726-na31-cefiro/#findComment-1124231
From where I come from(East Malaysia), the A31 is the only car that is still readily available.Hardly if not never, heard of the 260RS..hehehe... Furthermore, I know most of you dudes here use the A31 for drifting but I'd like a sleeper with an RB26 and 4WD in it(straight line beast). As for the 4WD system, I think I'd forget about all the wiring hassle and opt for the Veilside or APEXi torque split controller...unsure how much they cost though.
Speaking about cost, I can keep the labour rates low as I deal with many workshops almost everyday who can give me good deals.Furthermore, I do have my own mini workshop at my backyard(my dad's also an enthusiast).
If I see a huge possibility of converting the A31 into an RB26DETT/4WD beast, I'll set aside some $$ for it to happen sometime soon. What's holding me back is the modifications to the chassis that is needed to fit the gearbox/ATTESSA system(wider) as well as the front suspension and front subframe/crossmember to clear the moving parts..
FYI, the A31's price over here stays at around AUD 15k. How much is it over there?
https://www.sau.com.au/forums/topic/58726-na31-cefiro/#findComment-1124271
hehe I'm supposed to be in malaysia right now holidayin in KL... anyways... the cefiros in KL are all the RB24S carby versions arent they? I think I saw a few N/A RB20 ones but most of the souped up ones had 1JZ's in them. The Malay ceffies are a bit different to the Jap ones in that the brakes and suspension are a lil different.
An A31 landed and registered in australia can cost anywhere between 12kish for a good clean stock or mildly modified automatic (like the one my dad drives), about 9k for a used and abused drift pig, or a purposely built full tuning house car like inark RB26 ceffy (built by Ken Works as a drift "practice car") will cost you in excess of 16k without compliance and registration which should tip it at about 20k all up.
https://www.sau.com.au/forums/topic/58726-na31-cefiro/#findComment-1124292
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
