Well finally the trader ratings have been fixed up by Prank :D so I think everybody who has bought or sold anything in the last 6 months go through and find whoever they bought / sold the item(s) and leave some feedback.
To do that, click on the number in the profile to your left and click "submit feedback for xxxx" and go forth. Sometimes I think you do have to give people the benefit of the doubt if something does go wrong, although obviously if its somebody intentionally doing dodgy this needs to be pointed out.
I've just gone and done a whole heap I remember dealing with myself, to help along the process.
So will only work if everybody goes and backdates a little I reckon for recent transactions. This will help know who has been good and bad, and allow you to make an important decision in buying off somebody on here. Nobody wants to get ripped off.
p.s. This is related to general automative discussion because its er, buying and selling of automotive parts ;) and I thought it kind of important to know :) And also, people easily miss these things if not formally announced ;)
https://www.sau.com.au/forums/topic/58736-trader-ratings-active/
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
