I purchased these AFM's a while ago, now its time to put them on but... what the!!!! they are slightly different. The second pair has an additional pin. They have the same part number though. Can someone please enlighten me please.
part number is 22680-30P00-A36-000-N62 on both AFM's
pics attached
Thanks
https://www.sau.com.au/forums/topic/58741-z32-afm-question-help/
You have Z32 AFM's - lucky bugger !
Check my post in DIY section: "save $$$ installing Z32 AFM"
Unless you have a powerFC or other management to interpret the signal, they won't be much use. Factory ECU's will freak out.
I bought a nice new Bosch Z32 AFM.
Bosch make the AFM's for Nissan, they are exactly the same right down to the little orange sticker & part number.
I lie... :P
The only difference is the missing little nissan stamp under the plug to the left of the airflow direction stamp.
It set me back $285.
    • That's awesome. Fully serviced/full log book history for one of those cars is super rare from what I know. With JDM's like Skyline's, Supras, are quite hard to find one with full log book history. S15's seem to be somewhat of an exception, at least the spec s australian delivered models.
    • Hey all, It's been a bit since I have been able to update.  I pulled the fuel pump, first off it was a "universal" pump and the strainer was very clogged, and it was folded over on itself.  I replaced the fuel pump and all is well....  No more stalling.
    • That's convinced me I'll bump up the G30-660 to 770   Any idea if the difference in boost pressure? Cheers
    • When: Saturday 24th of May 2025 - All day Where: Sydney Dragway, Eastern Creek Cost: Varies - Book direct with the GTR Festival Website We will be there on the day with a stand please reach out via our interest form if you wish to help out with the stand. Limited parking will be available in the display area, first in first served with current members getting priority, please register your interest with the link above also. Please post any great photos you take on the day on this thread and we will try use some in our e-mails/website/social media
    • Hey guys so turns out this project is going to be much bigger than I thought haha but I've done some my homework and have done a few panels on my car, but one part I can just not visualise is this. If I do a spot repair and I put filler in a dent for example and sand outside of the repair with 320 grit lets say so the primer can stick as I will only put primer on that repair and the surrounding area and then repaint the whole panel. Don't I need to make sure that I don't put primer on the old clear coat? I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down, it's still shiny. I thought putting paint on clearcoat or primer on clearcoat is a bad idea because it won't stick. So in this scenario it's a bit different to mine but imagine someone doing a spot repair and only painting that small section of repair but the new paint is landing on the old clearcoat. What am I missing?
