First F**K Up on my car... help please :(
I just got up. Thanks for the suggestions. I will go and get some new plugs today and see if that fixes the problem.
My ECU is............... STANDARD
All it has maked on it is:
BU
23710 05U 60
MEC-R280 11Y19
NISSAN - Hitachi
Could be remapped though. Sometimes you wont get a sticker or anything on them indicating that they have been tampered with. But with a 9000rpm cut....its definately been fiddled with....
Like others have said, try the plugs, I had the same problem you described at 1.3bar though. I shortened the gap and now its fine.
Think of it as a candle in the wind, as the boost gets turned up the flame gets blown out. :P
robin its most probably got a remapped ECU in there dude, with the cams and T78 you got I'll bet my car (the cheaper one) it is. :P
as for the non spooling, you most probably have a leak in your hose or intercooler, so when your pressure builds up it gets worse, until the car can't compensate for it, at which point it cuts out.
My problem seems to have fixed itself or I fluked it this morning while checking over plugs and hoses. I just removed and blew,wiped then replaced.
So I'm off this morning to get the new plugs from Autobarn and I test the boost and no dramas at all. It's been sweet all day. I am going to start looking for another ECU and get the tune done ASAP.
My brother in-law has a MOTEC M48 out of his WRX that he is trying to sell http://www.wrx.com.au/forum/viewtopic.php?t=13406
I can pick it up offhim cheapish but I'm not sure if it will run the GTR I think it will but I'm not sure???
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
