I just wanted to let everyone know that I am now back terrorising the roads again. Thanks to boostn32 who sold me a sweet AFM.
I hate when she doesn't run right. Now it does so I'm happy again.
ok I'm over it now.
yep definately over it.
https://www.sau.com.au/forums/topic/58760-im-back-baby/
What you doing with fubar'd afm, I just want the plastic bit, as when Marc was fitting my pod, we snapped bits off which looked like they had been plastic welded anyway, but yeah it's all fibre glassed now, SO IT AINT GONNA BREAK!! :P
https://www.sau.com.au/forums/topic/58760-im-back-baby/#findComment-1125712
REFER TO AFA - VOTE NOW!! Thread.
https://www.sau.com.au/forums/topic/58760-im-back-baby/#findComment-1125730
Looks like I'm not back anymore, friggin frigged up oil pump won't friggin gimme any friggin pressure.
sorry for the frig fest but I'm a little upset about pouring all this money into this piece of sh1t. I think I might have to look at getting rid of it.
https://www.sau.com.au/forums/topic/58760-im-back-baby/#findComment-1128417
R32 GTST. I just rebuilt the motor after cooking it on the highway. It sat for a while while I saved the money to do the job. I did forged rebuild and everything had everything done properly except the turbo I left, the oil pump and the clutch pressure plate(new clutch plate though). So far....the turbo fried the bearings coz of the burnt oil that had been sitting on them for 4 months, the pressure plate is giving way, the oil pump is not holding pressure (probably the release valve). I just forked out for the AFM and it looks like there may be a problem with the coil packs as well.
This is turning into a nightmare.
I guess I'll know the extent of my worries when I pull the oil pump off tomorrow night.
https://www.sau.com.au/forums/topic/58760-im-back-baby/#findComment-1128639
I think what you actually want to use is "Circuit Board Cleaner"
Contact cleaner leaves a residue behind designed to lubricate the slides etc of a contactor. This lube is non conductive and oily, not something you want covering your hotwire afm?
Electronic circuit board cleaner is the gear to use, doesnt leave a residue and doesnt harm the AFM itself.
https://www.sau.com.au/forums/topic/58760-im-back-baby/#findComment-1128694
sounds like some issues still yet to fix :P
/hijack thread
where can i get a AFM for my 33 GTS - think it needs replaceing - or someone said spray some contactor cleaning into the sensor while the car is running to clean it?
/end hijack
:D
Send pm if you need a replacment one.
Steve
ps sorry for hijacking
https://www.sau.com.au/forums/topic/58760-im-back-baby/#findComment-1129299
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
