AFM to be destroyed!!
You'll have to be quick as I'm about to destroy it with the biggest bloody hammer I can find. hmmm.
This 20 pound sledge should do the trick.
Vote now. Should I destroy this remarkable piece of Nissan engineering?
Good Points: It is a Nissan product, it is off an RB20 - the sickest of all the engines, it serviced me well for 2 whole years, it didn't break down on me even when it was completely stuffed.
Bad points: I GOT BEATEN BY A FRIGGIN 2.0 N/A CALIBRA!!!
I will post photos soon and the Queensland SAU community will decide its fate.
https://www.sau.com.au/forums/topic/58761-afa-vote-now/
OH OH OH Can I buy it off you?!?! I just want the housing not the actual afm bit, just the plastic bit, if it fits rb25?
Other than that, the hammer is the only solution, but video it and post it up for all to share!!!!!
https://www.sau.com.au/forums/topic/58761-afa-vote-now/#findComment-1125686
Fire.
Its the only way.
..... Unless said fire is coupled with large explosion? I suggest putting 2 soda bulbs inside the afm, filling the rest of the space with the shit off sparklers, then wrapping the lot in alfoil. Insert a sparkler for a fuse, ignite, run to safe distance and film.
Cheers.
https://www.sau.com.au/forums/topic/58761-afa-vote-now/#findComment-1125968
Ok... this is the answer....
Bring it along to the next MSC so we can play a quick game of cricket with it as the ball (have to chuch it full toss, as they dont bounch well) but yeah... Then after a bit will can burn it... Then put it out then put a fire cracker in it.... Then burn it some more.... Then kick it round some in a game of soccer as it will be a molten ball by now.... Then we can burn it again.... Then maby, maby burn it one more time.....
Hows that???
https://www.sau.com.au/forums/topic/58761-afa-vote-now/#findComment-1131298
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
