hey guys, i got some stuff for sale
- JIC front negative upper link R33 GTST - $250 (these are Y27,800 at perfect run which is $344.418aud exluding freight and handling)
- JIC Magic tension rods for R33 GTST - $170 (together with negative upper link $350!!)
- HKS mushroom pod filter needs new element - $60
- A'PEXi N1 coilovers, just been rebuilt $1150
- Cusco upper arm for R32 $170
- Twin blitz BOVS with adaptor for R32 GTR $SOLD
- HKS Style dumppipe for S13 $SOLD
- HKS Pod with long HKS adaptor tube, needs element $80
i can COD any of these parts anywhere over australia!
thanks
arch
https://www.sau.com.au/forums/topic/58763-heeps-of-bits-n-pieces/
- JIC front negative upper link R33 GTST - $200 (these are Y27,800 at perfect run which is $344.418aud exluding freight and handling)
- JIC Magic tension rods for R33 GTST - $150
- A'PEXi N1 coilovers, just been rebuilt $1200
- Cusco upper arm for R32 $190
- Twin blitz BOVS with adaptor for R32 GTR $280
- HKS Style dumppipe for S13 $130
thanks
arch
prices dropped!
13_devil: These got rebuilt about 2 - 3 weeks ago, you can even see all the bushes are in brand new condition. These will last as long as a brand new set.
Mr GTS4: Im not to sure if they will fit i would most likely think they would, can anyone clarify this?
thanks
arch
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
