  • 3 weeks later...
ok here's a thought for us poor 32 owners. perhaps i should buy a tomei lock kit, and a bar. ie, use the tomei module to ensure the hicas computer doesn't stuff up my front power steering or activate the light, and use the bar to enable me to remove the weighty hicas unit and it's associated bits...hmm that could be the go. obviously it's the most expensive way, but should give the best result.
  • 3 weeks later...
I should get off my ass and buy a Tomei kit to reproduce the module :D
BTW I will not be producing bars from Tuesday 15 Nov until after Thurs 16 Dec as I will be out of country. I'm pretty sure the Vic Copper staying at my place can't weld either so he won't help ;)
Also, once I finish the current stock of about 4 R33/34 and 10 R32/180/Silvia bars I won't do any more until next year sometime.
geoff, when i'm in japan (leaving in about 7 weeks) I'll pick up one of the tomei kits and bring it back for you to expose it's goodies.
are they cheap over there?
i would prefer to get one of them if they were the same price as the lock bar, due to the power assistance issues with r33's, which is why i still have not made up my mind to get a lock bar.. maybe u could get me one too :P:(
Yeah I'll raise my hand on this issue. I'm not a fan of feeling the rear end behave independent of what I'm doing up front. Wasn't sure what the best way to go about all this was. Is the consensus that the bar is effect and cheap, (and requires a bulb removal in the dash) or are people finding the Tomei kit preferable? I’m not too fussed about weight as I’m not out to pull 10’s or anything. As I understand it, the price difference is something like $60 or so for the bar vs $200+ for the Tomei kit?
Cheers
i would prefer to get one of them if they were the same price as the lock bar, due to the power assistance issues with r33's, which is why i still have not made up my mind to get a lock bar.. maybe u could get me one too :):D
yeah i think they are about $120 or $130 from memory. i still think the lock bar is the best option, particularly for a 33, it's just that it needs a little more fiddling to fit on a 32. The tomei thing is certainly easy to fit, but it would be nice to get rid of the unnessary weight (which properly fitting the bar will do).
Ok so properly fitting the bar removes the hardware associated with the HICAS system and just leaves the ECU behind (which requires a bulb removal on the dash and wont effect the speed sensitive power steering)?
quick question probably sounds stupid but yeh... what would happen if u just unplugged all the electrical shit from the HICAS bar as u did in picture number 1... but left the hicas bar as is??
or if you yanked out the hicas fuse, what that do the trick ???
no, neither of the above to ideas will work. without the rear steering rack being controlled you will have problems. both you guys have 33s so it's really simple. buy and fit a bar, remove dash light, get wheel allignment. But Geoff has more detailed instructions in his sig.
so this bar replacement that geoff supplies, is that like having a locked diff in replacement of the HICAS bar??? ... or the hicas and differential have nothing to do with each other?
hicas and diff have nothing to do with each other. hicas is the rear steering rack. it changes the toe as it sees fit. replacing the rack with a solid bar stops this and gives a more predictable rear end.
Hey guys on the hicas matter i have a 32, and i completly removed eveything to do with hicas and installed a lock bar, this includes chnagin the power steering pump, but one thing i did find is that as soon as you unplug the hicas computer the steering goes really heavy, and leaving the computer in makes the steering go heavy at higher speeds...now to the point....if you just want really light steering all the time i figured out using trial and error, that there is a little variable solenoid on the front rack, this is controlled by the hicas computer. if you unbolt the small solenoid (3 allen key bolts) you will find 2 holes which allows fluid to pass through when the solenoid isnt energized, and when you pick up speed this valve closes slightely causing the steering to get soft....so to have soft steering with the hicas computer out you have to take the solenoid off the rack and cut out a plate to cover the holes (steering is nice and soft when these holes are cover) this stops fluid travelling out one hole then through the solenoid and into the other hole....you simply have to bog up the holes with sumthing....i used a alluminium plate and just drilled 3 holes in it to line up.....and thats all there is to it to have soft steering with hicas computer removed!
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
