  • 3 weeks later...
ok here's a thought for us poor 32 owners. perhaps i should buy a tomei lock kit, and a bar. ie, use the tomei module to ensure the hicas computer doesn't stuff up my front power steering or activate the light, and use the bar to enable me to remove the weighty hicas unit and it's associated bits...hmm that could be the go. obviously it's the most expensive way, but should give the best result.
  • 3 weeks later...
I should get off my ass and buy a Tomei kit to reproduce the module :D
BTW I will not be producing bars from Tuesday 15 Nov until after Thurs 16 Dec as I will be out of country. I'm pretty sure the Vic Copper staying at my place can't weld either so he won't help ;)
Also, once I finish the current stock of about 4 R33/34 and 10 R32/180/Silvia bars I won't do any more until next year sometime.
geoff, when i'm in japan (leaving in about 7 weeks) I'll pick up one of the tomei kits and bring it back for you to expose it's goodies.
are they cheap over there?
i would prefer to get one of them if they were the same price as the lock bar, due to the power assistance issues with r33's, which is why i still have not made up my mind to get a lock bar.. maybe u could get me one too :P:(
Yeah I'll raise my hand on this issue. I'm not a fan of feeling the rear end behave independent of what I'm doing up front. Wasn't sure what the best way to go about all this was. Is the consensus that the bar is effect and cheap, (and requires a bulb removal in the dash) or are people finding the Tomei kit preferable? I’m not too fussed about weight as I’m not out to pull 10’s or anything. As I understand it, the price difference is something like $60 or so for the bar vs $200+ for the Tomei kit?
Cheers
i would prefer to get one of them if they were the same price as the lock bar, due to the power assistance issues with r33's, which is why i still have not made up my mind to get a lock bar.. maybe u could get me one too :):D
yeah i think they are about $120 or $130 from memory. i still think the lock bar is the best option, particularly for a 33, it's just that it needs a little more fiddling to fit on a 32. The tomei thing is certainly easy to fit, but it would be nice to get rid of the unnessary weight (which properly fitting the bar will do).
Ok so properly fitting the bar removes the hardware associated with the HICAS system and just leaves the ECU behind (which requires a bulb removal on the dash and wont effect the speed sensitive power steering)?
quick question probably sounds stupid but yeh... what would happen if u just unplugged all the electrical shit from the HICAS bar as u did in picture number 1... but left the hicas bar as is??
or if you yanked out the hicas fuse, what that do the trick ???
no, neither of the above to ideas will work. without the rear steering rack being controlled you will have problems. both you guys have 33s so it's really simple. buy and fit a bar, remove dash light, get wheel allignment. But Geoff has more detailed instructions in his sig.
so this bar replacement that geoff supplies, is that like having a locked diff in replacement of the HICAS bar??? ... or the hicas and differential have nothing to do with each other?
hicas and diff have nothing to do with each other. hicas is the rear steering rack. it changes the toe as it sees fit. replacing the rack with a solid bar stops this and gives a more predictable rear end.
Hey guys on the hicas matter i have a 32, and i completly removed eveything to do with hicas and installed a lock bar, this includes chnagin the power steering pump, but one thing i did find is that as soon as you unplug the hicas computer the steering goes really heavy, and leaving the computer in makes the steering go heavy at higher speeds...now to the point....if you just want really light steering all the time i figured out using trial and error, that there is a little variable solenoid on the front rack, this is controlled by the hicas computer. if you unbolt the small solenoid (3 allen key bolts) you will find 2 holes which allows fluid to pass through when the solenoid isnt energized, and when you pick up speed this valve closes slightely causing the steering to get soft....so to have soft steering with the hicas computer out you have to take the solenoid off the rack and cut out a plate to cover the holes (steering is nice and soft when these holes are cover) this stops fluid travelling out one hole then through the solenoid and into the other hole....you simply have to bog up the holes with sumthing....i used a alluminium plate and just drilled 3 holes in it to line up.....and thats all there is to it to have soft steering with hicas computer removed!
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
