hey jason, I have one of geoff's bars on order, and will need it fitted (no tools here in sydney :rofl: ) so does your $120 include the allignment?
on a side note, I got home tonight with my GTR blowing a lot of smoke as I pulled in the garage! the engine is only 1500km old, with 3 oil changes under its belt! and the turbos are new at the time also...... oh and low boost too! only .9 bar !!!
Im off to ring the builder in the morning, but I am seriously hoping it is something minor or there will be tears!
maybe a blocked PCV? :S:S:S
cheers, and thanks to geoff for taking the time to make these for us guys!!!
white smoke....
spoke to morgs and to SK today.... they think it is oil breathing into the intake pipes, and I have checked the pipes... yep laced with oil!
so I need a catch can!!! and now to clean the intercooler and associated piping ...
gcg catch tank??
Just to clarify some of the questions about R32 GTR....
To remove HICAS altogether.....buy one of Geoff's bars, and either....a new power steering pump with 1 output, or a bolt the right size to replace the rear line outlet.
Disconnect the 2 ball joints at the hubs, and then remove the 2 bolts holding the HICAS bar to the subframe. Be amazed at how heavy it is.
Disconnect the 2 lines from the chassis that go to the HICAS bar, there are a couple of brackets holding the lines to the subframe.
Disconnect the 2 lines right to the front of the car, right up at the HICAS solenoids next to the plenum.
Remove both inlet and outlet lines from the HICAS solenoid (these lines run back to the power steering pump and power steer reservoir. Unlpug the wires and remove the bracket. Enjoy how much easier it is to remove your oil filter.
Remove the rear line from the power steering pump, unbolt the brackets and cut the metal pipe as it links around the power steering lines underneath (unless the engine is out in which case it just lifts out :rofl:)
Remove the line that run from the HICAS solenoid to the cooler to the reservoir. Remove the whole cooler and all its brackets. Remove the other line that runs from the solenoid to the pipe you just cut.
Put a nice big bolt in a short piece of line to block the empty exit from the reservoir.
Clean up the power steering fluid that is all over your garage floor.
Like anything, double check to make sure you have the right pipes, esp before you start cutting! There will be only 2 power steer lines left in the engine bay, it will go from one of the reservoir outlets to the front of the power steer pump, around the engine bay to the steering rack, then back around the back of the engine bay and back to the reservoir.
Remove the rear line from the power steering pump, unbolt the brackets and cut the metal pipe as it links around the power steering lines underneath (unless the engine is out in which case it just lifts out ;))
That's great, I think that's what I've been searching for. I have a R32 GTST. Is this a similar setup to the GTR? Also, can I use the original pump, or what is an alternative pump to use? To clarify, can I remove eveything bar what goes from the reservoir to the pump, to the rack and back to the reservoir? I have a couple of metal plugs to go with the 2 spacers and 2 domed nuts from the locking bar kit. Where do I use them?
Thanks
Mitch :P
Hi Duncan,
Have you gone through this process and have it running in your car? Is all OK without the extra line (that used to go to the HICAS solenoid) and without the cooler?
In my mind the extra line may have relieved pressure in the system - though I would prefer to listen to your advice as someone who has gone through the exercise!
Yes we;ve made the changes above and given the car a *very* thorough work out since. No problems with the car or power steering.
Our main concern was whether the pump will last with 1 outlet just blocked off...dunno...if it dies we will be replacing it with a 1 outlet pump like an r33.
I'm not sure if a 32 gtst is the same but I suspect it is
Is the R33 pump a direct replacement?
Which is the Hicas outlet on the R32 pump?
Thanks again
Mitch:)
I'm not sure but apparently so,
And the HICAS outlet is the rear one on the Power Steering pump. But for goodness sake before you start pulling it out...double check everything!
Right, blocked the rear outlet from the pump, and also the return to the reservoir.
Haven't yet swapped out the Hicas rack, but there is Power Steering fluid pissing all over from somewhere or other. I thought it was from the main return to the reservoir, so replaced it with a braided hose, but after taking it for a run out, there's an explosion of fluid all under the engine, hoses, suspension-everywhere.
Is there a possibility that the rear outlet being blocked is causing excess pressure in the system?
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
