it simply pops out upon breakage...then gets copied by a glass cutting machine, this is best done by a compliancer, trust me... you will, WILL stuff it up... do NOT go down this road...
ABOOORRRRRTTTT!!!!
https://www.sau.com.au/forums/topic/58789-mirror-removal/#findComment-1125014
Cheers guys,
After your advice i'm going to be getting the place that did my side intrusion bars to do it, i have to get them to do my driver's side seatbelt coz i have no buckle and no one can source me a used one from a wrecker, apparently its illegal to sell used seatbealt buckles :P
I'll post up pics of my ride as soon as its back from the paint shop.
Cheers
David
https://www.sau.com.au/forums/topic/58789-mirror-removal/#findComment-1126311
oz_cefiro, I'll check at the office to see if we have any seatbelts available that'll fit a ceffy :P in VIC you don't have to change seatbelts to get compliance cert on a 15yr old, so we might not, but its worth checking as some SEVS workshops have spare ones from the cars they change seatbelts on.
As for mirror it can't be that hard surely... just use a very wide knife like a cleaver to wedge into the mirror and pop it out. Heat is a good thing too so do it on a hot day or heat your mirror with a heat gun first. Common mistake is to use a screwdriver, which is thin and narrow... it has less contact area with the glass, so it exerts more pressure at one spot. Spread the contact area out over the glass and it'll pop out no probs.
https://www.sau.com.au/forums/topic/58789-mirror-removal/#findComment-1126315
oz_cefiro, I'll check at the office to see if we have any seatbelts available that'll fit a ceffy :D in VIC you don't have to change seatbelts to get compliance cert on a 15yr old, so we might not, but its worth checking as some SEVS workshops have spare ones from the cars they change seatbelts on.
Cheers funkymonkey, its the same over here, under the 15 year rule the seat belts don't need to be changed, but when it arrived my car didn't have the driver's side buckle. I've been told by other guys on this forum that R32 buckles also fit, if you can source me one in victoria, i have family that live their and they could pick it up from you. Do you know how much i would be looking at for a seatbelt buckle, i also need the bolt that screws it into the seat.
Cheers
David
https://www.sau.com.au/forums/topic/58789-mirror-removal/#findComment-1126682
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
