Hi everybody.
New to forum and the Skyline as of this weekend gone.
Having come from a carbied big block ford with little technology this is all new, please help?
As best i can tell i have a standard ceramic turbo and most other ancilleries are standard except for a k&N air filter and a 3 inch exhaust from dump pipe and large aftermarket intercooler and 2 stage boost control.
My problem is this.......
On standard boost the car seems to go ok with little drama. As soon as the boost control is turned up on either the low variable or the high variable it develops a nasty surge in the mid range and cleans itself out in the 5500 to 7000 rpm range.
Have changed plugs to genuine nissan spec platinum plugs ( i work in a Nissan dealership) to rule out that with no change!!!!!!
Have only had the car for 3 days and have only driven for 150 klms so far but would like it run cleanly before giving it some serious stick
Had the workshop look over breifley but hard to get stuff done being staff, BUT, It appears that the TPS is a dual plug which would indicate it may be for an auto????? Can anyone advise as to what i should be looking for in and around the engine bay
Thanks in advance....
Also, can anyone tell me whether it is series 1 or 2. It is a late 1995 GTST manual R33 2 door
https://www.sau.com.au/forums/topic/58795-help-with-engine-miss-long/
Might need a bit more info than that. I'm guessing way too much boost. Have you got a gauge?
Does it have the power transistor pack at the rear of the plug cover or not?
Series 2 has that circuitry incorporated in the coil packs so not visible.
Yes it has the factory guage plus an aftermarket one. The aftermarket reads in bar and gets to about 0.7>0.8. the original guage wont read full boost but i really don't want hold my foot into it yet incase it is leaning out.
In the coil packs there appears to be nothing after no6 coil pack. only the harness that runs into the main harness which has a white wire looped on itself not going anywhere?
Thanks
when you replaced the spark plugs what was the gap?
try smaller gap most people seem to say around the .6mm to .750mm for best results
that may be a help to you if you are runing bigger boost
Put in at factory settings at 1.1. Theses are 224011p116 nissan part number, which come from ngk anyway. The ngk number on the same box is NGKpfr6g-11 platinum tip. What i took out was bkr6e11 which were set @ .75 mm . The plugs look fairly new and clean with only a few with some slight brownish discolouration on the porcelin.
We moved the TPS last night to the lean side and it did exagerate the condition. What sort of readings should come from TPS?
Thanks
about the series look at the build plate also quick checks are if your dash surround is a rough surface its series 2 if its smooth series 1 there are heaps of little other checks like abs for series 2
as for your questionon the throttle position sensor
this may help
On the TPS is two sets of wires, one is the idle contacts, the other is the variable resistor, The plug that plugs directly on to the TPS with 2 wires is the idle contacts, the other set with the wiring connector about 5cm's or so away from the TPS and with 3 wires is the variable resistor, can't remember wiring colors, in the lot of 3 wires you have to get the correct one, with the ignition on and everything connected get a multimeter and connect one lead to earth on the battery, the other lead you need to backprobe one of those 3 wires, you need to get a reading of around 0.5 volts, if not, loosen the TPS screws and rotate it to get exactly 0.5 volts with the throttle fully closed.
Now, with that set the idle contacts are probably crap.
You now need to connect the multimeter to the other set of two wires, unplug the connector on the TPS and put both leads onto the two terminals on the TPS, they should be closed, rotate the throttle slowly till the multimeter shows no contact, this should be JUST off idle, if not, well, the only way to fix it is to remove the TPS and dismantle it and bend the contacts inside to get it right as you can't rotate the TPS to fix it as you will muck up the other setting, It takes a while to get it right
One thing to add, the plug that plugs directly on to the TPS may have three wires, have to check it out but, manuals may have two wires, auto's may have three wires, the two top pins are the idle contacts.
also regap new plugs to .6mm otherwise on boost it will run like poo at 1.1mm which the NGKpfr6g-11 are set at thus the -11 at the end of model number
hope i help
this is common on RB25DET
coils usually have small hairline cracks, so spark arks on head and is weaker,
ont high boost, ECU runs rich, and retards timing to protect engine. At this point the cracks in your coil become noticable as your car starts to hesitate. The problem is most apparent at 4500 -> 6000 rpm
cheapest solution is:
araldite, silicone or whatever the cracks on the coils AND get a SAFC to lean out your mixtures.
gapping down your spark plugs may make it less noticable, but won't fix it.
best solution:
new spitfire coils + new stand alone ECU
also the more expensive solution
I have gone for the cheapest solution, and my car runs incredibly smooth. The problem does not exist anymore
Read through this thread, as it details where to cover the cracks on your coils.
Invest in a SAFC to adjust your Air/Fuel ratios - you will NOT regret it.
 best solution:
Will the unichip do the job for fuel curve. I am speaking to a unichip guy tommorrow to find out what are it's features.
I strapped up the coil pacs today with nitto tape and reggapped plugs to 0.71 and it runs a s@#$load better. will be able to take for a bit of a drive sat or sun
Try checking knock sensors, not sure if the 33 has them also but it should do. They will effect you in this exact rev range.
TPS, KNOCK SENSORS and AFM are all integrated into the fuel map and Timing map so any of them could be faulty. That or what the others are saying about the coil packs.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
