Hi,
I have a R33 GTS25T with minimal mods. HKS exhaust from cat back and pod filter. I spoke to a tuner who advised me that if I was to spend $5k then the best thing to do would be a new ECU (cost of $3,000 tuned), FMIC ($2,000) and dump pipe for $400. Does this seem reasonable and logical?
Is $3k for the ECU good value. Would it be just as good and cheaper to get a GReddy e-manage or something like that.
How much additional power can I get from a different ECU alone? Is it possible to get more power while increasing the fuel efficiency?
Cheers.
https://www.sau.com.au/forums/topic/58802-is-this-advice-right/
i think those prices are very high.. Im in Melbourne however I believe the following would be closer to the mark:
Apexi PFC: $1500 Fitted and tuned
Front Pipe and Highflow Cat: $600 fitted
FMIC: Max $1500
Boost Controller: $80
Prices are for new items.
With what you already have as well as Computer, Cooler and Exhaust you should be close to the 200rwkw mark with better fuel economy.
That is my current setup on 12-13psi and i am currently getting about 12L/100km city driving and 9L/100km freeway.
You will notice a huge difference in the way the car feels.
FMIC: Max $1500
Just don't forget to add at least $400 for the PFC to be tuned to the above list.
a PowerFC is $1100 delivered, and they come with a H/C, you cant buy them anymoer separate. They are a package now.
Tuning should be around $500
With your left over cash, i suggest you look at a new clutch if yours is stock as it wont last too long with the new found power.
And if you still have cash, then look at brakes before looking to upgrade turbo, thats just my opinion. I like to go fast, but i like to stop faster
cheers
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
