Restrictor goes in the oil line to the head to keep oil in the sump. There is one in there standard but many put in an even smaller one
Courtesy of tomei website: http://www.tomei-p.co.jp/_2003web-catalogu...RB_oillube.html
https://www.sau.com.au/forums/topic/58817-n1-oil-pump/#findComment-1125985
my understand (and I don;t know much) is that the standard pumps put waaay too much oil in the head at high revs. Together with oil sloshing around in long high G corners you can end up with no oil at the pick up.
Result no oil being pumped = dead engine quick smart.
We do 4 changes to the stock enigne for racing 1 - restrictor in the line to the head, 2 - bigger sump, 3 - foam in the cam covers above the standard baffle to stop oil collecting there 4 - big oil cooler.
The car with those mods has lated 18 hard racing month no probs.
My dead standard one died first track day.
Its no guarantee but you should give yourself the best chance. On the other hand, I wouldnt (didn't) bother with all this until it went kaboom in the first place, removing and rebuilding an rb26 is an expensive process :P
https://www.sau.com.au/forums/topic/58817-n1-oil-pump/#findComment-1127255
yeah the only expensive part in that was the sump about $500, its worth doing it all while its out, I would hate to have to pull it out again soon.
The restrictor is just a 1.5mm copy of the 2mm one that is in there. Just get it made up by any machine shop.
We are also machining the crank while it is out so it engages the oil pump better. Have a look at the oil pump that came out and see if the flat part that engages the crank is worn at all.
https://www.sau.com.au/forums/topic/58817-n1-oil-pump/#findComment-1128031
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
