I know that this question has been asked many times before and I've done a search and have gathered some information but I still need some more specifc stuff.
I know these differences:
R33 gts4:
Engine: Rb25DE
Diff ratio: 4.36
brakes: 4 pot simiseto front and 2 pot rear ???
Suspension not has tough as GTR, i.e. softer sway bars etc...
R33 GTR:
Engine: RB26DETT
Diff ratio: 4.11
brakes: brembo's all round
What I need to know is the following.
1) Are the gearboxes exactly the same, i.e. ratio's and gear set strength
2) Are the drive shafts the same strength
3) Although the diff ratios are different, are the diff strengths the same,
4) Does the 4wd ATTESA system act the same way in both cars, i.e. sampling rate, torque split etc
5) do the GTS4's have a 5 stud wheel pattern (I read somewhere that non-turbos have a 4 stud)
https://www.sau.com.au/forums/topic/58859-differences-bn-r33-gts4-r33-gtr/
1) Are the gearboxes exactly the same, i.e. ratio's and gear set strength-Yes-gear ratios different
2) Are the drive shafts the same strength-no but close
3) Although the diff ratios are different, are the diff strengths the same, yes
4) Does the 4wd ATTESA system act the same way in both cars, i.e. sampling rate, torque split etc-no
5) do the GTS4's have a 5 stud wheel pattern (I read somewhere that non-turbos have a 4 stud) 5 stud
Ant, u sure about the 4 stud hubs???
Yep, pretty sure, though I heard rumours that late 97 - 98 (ie end of R33 production) models got 5 stud hubs on some random cars - probably a parts run-out thing.
I've got an HPI article which compared the R32 and R33 GTS4's and the brake types are mentioned, will dig that up and check.
Are you referring to R32, 33 or R34 GTS4's?
i am a dedicated High performance imports (HPI) reader and i have the issue u have just mentioned. the r32 had 4 pot calippers while the r33 had 2 pot calippers for the brakes. generally the r32 has the better things as it also has a turbo, the r33 gts-4 is n/a
I have a 95R33 GTS4 It did have 4 stud hubs and twin piston calipers on the front and single piston on rears. The rotors are smaller and the rears are solid. I have upgraded to the turbo breaks all round. The rear drive shafts are smaller in diameter to the turbo GTS and GTR ones.I have a set of GTST shafts that I will be installing soon they are 3mm bigger in dia. The attessa computer is the same as R33 gtr (the wiring is different between r32 and r33 GTR's. Transfer case is the same and gearbox is as strong however they have different ratios to GTR. It has a clutch set up the same as R32 GTR.
The suspension set up is different. The rear struts are the same as GTST and the front is different to both. I tried to put Vspec GTR struts in the front so I could lower it but it stayed the same height (strange) I believe the lower mount for the strut on a GTR sits 40mm lower. I ended up buying bilstein height adjustables :headspin: made to suit. Has a front sway bar but unsure of size (can measure if you want) but had no rear bar at all. I have one from a GTST that will fit but will be using whiteline anyway. The rear of the tailshaft has a universal jount the same as GTST, GTR is different It looks more like a CV. All front shafts are the same as far as I know. The sump is the same. No R33 GTS4 has hicas but from what I have heard it is no great loss anyway (saves on weight). The speedo is the same tacco redlines lower and does not have GTR written on it and the surround is black not carbon look. has a different shape climate control unit to GTR as the 3 centre gauges sit at the top and climate control is in the middle on GTR. I have installed these gauges which meant I had to buy thr GTR climate control as well.
The rest of the interiour is GTS.
I have an RB30 with forged internals all ready to assemble and go in After I spent a shit load of time making an adapter plate for the 4wd sump to bolt on. :headspin:
I bought a pair of Trust TD05H 18G turbos from Advan ready for the manifold to be made.
So you can see being NA did not bother me as I would have ditched the standard engine and turbo anyway. As the car only cost me 14k it allows me to spend a shitload on the engine/gearbox/clutch etc. Hopefully I should end up with a 10-11 sec daily driven Skyline for under 40K
Hope this info helps. Any other questions send me a pm.
Gilly.
I'm refering more to r33 gts4's and also the r34 gts4 (I know that they aren't many r34 4wd's around so info on them might be hard to come by) but thanks for all the info guys....
gilly, u reckon that the attessa system acts the same way as an R33/R34 non-vspec GTR but darkrams69 reckons they are different?? Anyway 100% sure????
Also, if I bolted an Rb26 into an r33/r34 gts4, can I leave the gearbox, and diff as is. I guess I could bolt the front gts4 diff (ratio 4.36) onto the rb26 and leave the rear one in place. Would this setup hold up or would it break?????
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
